Population modeling of early COVID-19 epidemic dynamics in French regions and estimation of the lockdown impact on infection rate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We propose a population approach to model the beginning of the French COVID-19 epidemic at the regional level. We rely on an extended Susceptible-Exposed-Infectious-Recovered (SEIR) mechanistic model, a simplified representation of the average epidemic process. Combining several French public datasets on the early dynamics of the epidemic, we estimate region-specific key parameters conditionally on this mechanistic model through Stochastic Approximation Expectation Maximization (SAEM) optimization using Monolix software. We thus estimate basic reproductive numbers by region before isolation (between 2.4 and 3.1), the percentage of infected people over time (between 2.0 and 5.9% as of May 11 th , 2020) and the impact of nationwide lockdown on the infection rate (decreasing the transmission rate by 72% toward a R e ranging from 0.7 to 0.9). We conclude that a lifting of the lockdown should be accompanied by further interventions to avoid an epidemic rebound.
SISTM_COVID19_20200425.pdf (1.69 Mo) Télécharger le fichier
hal-02555100 , version 1 (28-04-2020)
  • HAL Id : hal-02555100 , version 1
Mélanie Prague, Linda Wittkop, Quentin Clairon, Dan Dutartre, Rodolphe Thiébaut, et al.. Population modeling of early COVID-19 epidemic dynamics in French regions and estimation of the lockdown impact on infection rate. 2020. ⟨hal-02555100⟩
379 Consultations
189 Téléchargements
