Abstract : The MAP-Elites quality-diversity algorithm has been successful in robotics because it can create a behaviorally diverse set of solutions that later can be used for adaptation, for instance to unanticipated damages. In MAP-Elites, the choice of the behaviour space is essential for adaptation, the recovery of performance in unseen environments , since it defines the diversity of the solutions. Current practice is to hand-code a set of behavioural features, however, given the large space of possible behaviour-performance maps, the designer does not know a priori which behavioural features maximise a map's adaptation potential. We introduce a new meta-evolution algorithm that discovers those behavioural features that maximise future adaptations. The proposed method applies Covari-ance Matrix Adaptation Evolution Strategy to evolve a population of behaviour-performance maps to maximise a meta-fitness function that rewards adaptation. The method stores solutions found by MAP-Elites in a database which allows to rapidly construct new behaviour-performance maps on-the-fly. To evaluate this system , we study the gait of the RHex robot as it adapts to a range of damages sustained on its legs. When compared to MAP-Elites with user-defined behaviour spaces, we demonstrate that the meta-evolution system learns high-performing gaits with or without damages injected to the robot.
