New $L_2$−$L_0$ algorithm for single-molecule localization microscopy
Among the many super-resolution techniques for microscopy, single-molecule localization microscopy methods are widely used. This technique raises the difficult question of precisely localizing fluorophores from a blurred, under-resolved, and noisy acquisition. In this work, we focus on the grid-based approach in the context of a high density of fluorophores formalized by a 2 least-square term and sparsity term modeled with 0 pseudo-norm. We consider both the constrained formulation and the penalized formulation. Based on recent results, we formulate the 0 pseudo-norm as a convex minimization problem. This is done by introducing an auxiliary variable. An exact biconvex reformulation of the 2 − 0 constrained and penalized problems is proposed with a minimization algorithm. The algorithms, named CoBic (Constrained Biconvex) and PeBic (Penalized Biconvex) are applied to the problem of single-molecule localization microscopy and we compare the results with other recently proposed methods.
Origin : Publisher files allowed on an open archive
