Generalized Transmuted Family of Distributions: Properties and Applications, Hacet J. Math. Stat, vol.46, pp.645-667, 2017. ,
A new method for generating families of continuous distributions, Metron, vol.71, pp.63-79, 2013. ,
Testing Parameters of a Gamma Distribution for Small Samples, Technometrics, vol.51, pp.326-334, 2009. ,
A Statistical Model for Life-Length of Materials, J. Am. Stat. Assoc, vol.53, pp.151-160, 1958. ,
Estimation for a Family of Life Distributions with Applications to Fatigue, J. Appl. Probab, vol.6, pp.328-347, 1969. ,
Acquisition of resistance in guinea pigs infected with different doses of virulent tubercle bacilli, Am. J. Epidemiol, vol.72, pp.130-148, 1960. ,
Monthly Estimates of C-13/C-12 (per mil) in Fossil-Fuel Carbon Dioxide Emissions from the U.S.A.. Data file accessed at cdiac, Clinical Laboratory Science, vol.11, pp.223-227, 1998. ,
Salience of the self and salience of standards: Attempt to match self to a standard, 1990. ,
An Analysis of Some Failure Data, J. Am. Stat. Assoc, vol.47, pp.113-150, 1952. ,
Discrimination between the Log-Normal and the Weibull Distributions, Technometrics, vol.15, pp.923-926, 1973. ,
Histopathological changes in relation to cadmium concentration in horse kidneys, Environ. Res, vol.26, pp.1-21, 1981. ,
Estimation of Exponential Survival Probabilities with Concomitant Information, Biometrics, vol.21, pp.826-838, 1965. ,
Sexual Activity and the Lifespan of Male Fruitflies: A Dataset That Gets Attention, J. Stat. Educ, vol.2, pp.1-4, 1994. ,
, The Elements of Statistical Learning, 2008.
A Critical Appraisal of 98.6 F, the Upper Limit of the Normal Body Temperature, and Other Legacies of Carl Reinhold August Wunderlich, JAMA, vol.268, pp.1578-1580, 1992. ,
The exponentiated Weibull family: Some properties and a flood data application, Commun. Stat.-Theor. M, vol.23, pp.1149-1171, 1996. ,
A Simplex Method for Function Minimization, Comput. J, vol.7, pp.308-313, 1965. ,
A Bootstrap Control Chart for Weibull Percentiles, Qual. Reliab. Eng. Int, vol.22, pp.141-151, 2006. ,
On the Laws of Inheritance in Man: I. Inheritance of Physical Characters, Biometrika, vol.2, pp.357-462, 1903. ,
An efficient method for finding the minimum of a function of several variables without calculating derivatives, Comput. J, vol.7, pp.155-162, 1964. ,
Effects of environmental pollutants upon animals other than man, Numerical Recipes: The Art of Scientific Computing, vol.6, pp.443-463, 1972. ,
Models for extremes using the extended three parameter Burr XII system with application to flood frequency analysis, Hydrolog. Sci. J, vol.49, pp.685-702, 2004. ,
The Weight of Euro Coins: Its Distribution Might Not Be As Normal As You Would Expect, J. Stat. Educ, vol.14, pp.1-14, 2006. ,
A Comparison of Maximum Likelihood and Bayesian Estimators for the Three-Parameter Weibull Distribution, J. R. Stat. Soc. C-Appl, vol.36, pp.358-369, 1987. ,
Numerical maximum log likelihood estimation for generalized lambda distributions, Comput. Stat. Data An, vol.51, pp.3983-3998, 2007. ,
