Feasibility of on-line speed policies in real-time systems - Archive ouverte HAL Access content directly
Journal Articles Real-Time Systems Year : 2020
(1) , (2) , (1)
1
2
We consider a real-time system where a single processor with variable speed executes an infinite sequence of sporadic and independent jobs. We assume that job sizes and relative deadlines are bounded by C and ∆ respectively. Furthermore, S max denotes the maximal speed of the processor. In such a real-time system, a speed selection policy dynamically chooses (i.e., on-line) he speed of the processor to execute the current, not yet finished, jobs. We saythat an on-line speed policy is feasible if it is able to execute any sequence ofjobs while meeting two constraints: the processor speed is always belowSmaxand no job misses its deadline. In this paper, we compare the feasibility regionof four on-line speed selection policies in single-processor real-time systems,namely Optimal Available (OA) (Yao, Demers, and Shenker, 1995), Aver-age Rate (AVR) (Yao, Demers, and Shenker, 1995), (BKP) (Bansal, Kimbrel,and Pruhs, 2007), and a Markovian Policy based on dynamic programming(MP) (Gaujal, Girault, and Plassart, 2017). We prove the following results: – (OA) is feasible if and only if Smax ≥C(h∆−1+ 1), where hn is the n-th harmonic number (hn=∑ni=11/i≈logn). – (AVR) is feasible if and only if Smax ≥Ch∆. – (BKP) is feasible if and only if Smax≥ eC (where e= exp(1)). – (MP) is feasible if and only if Smax≥C. This is an optimal feasibility condition because when Smax< C no policy can be feasible. This reinforces the interest of (MP) that is not only optimal for energy con-sumption (on average) but is also optimal regarding feasibility.
Online_policy_comparisonsFinal.pdf (431.87 Ko) Télécharger le fichier
Dates and versions
hal-02557148 , version 1 (29-04-2020)
Identifiers
Cite
Bruno Gaujal, Alain Girault, Stéphan Plassart. Feasibility of on-line speed policies in real-time systems. Real-Time Systems, 2020, ⟨10.1007/s11241-020-09347-y⟩. ⟨hal-02557148⟩
107 View
273 Download
Share
