, The seven predictions obtained for v c (k + 2) are compared using a cost function g 2
, The voltage vector v i that minimizes this function is then chosen and its corresponding switching state is applied at the next sampling instant k + 1
, The output current, i o (k + 1), value used for predictions k + 2 is estimated using (3.13). Here, in this work the present value of output current i o (k) is measured and feeded to predict the value of the output voltage and the filter current, v c (k + 1) and i f (k + 1)
Model predictive controllers: A critical synthesis of theory and industrial needs, Advances in Chemical Engineering, vol.26, 2001. ,
, Model Predictive Control, 1999.
URL : https://hal.archives-ouvertes.fr/hal-00256633
Predictive Control With Constraints, 2002. ,
Digital signal processors for modern control systems, Control Eng. Practice, vol.5, issue.4, pp.449-458, 1997. ,
, IEEE recommended practices and requirements for harmonic control in electric power systems, Institute of Electrical and Electronics for Engineerings, pp.519-1992, 1993.
Predictive current control of a voltage source inverter, IEEE Trans. Ind. Electron, vol.54, pp.495-503, 2007. ,
Power-electronic systems for the grid integration of renewable energy sources: A survey, IEEE Trans. Ind. Electron, vol.53, pp.1002-1016, 2006. ,
Overview of control and grid synchronization for distributed power generation systems, IEEE Trans. Ind. Electron, vol.53, pp.1398-1409, 2006. ,
Model predictive control -a simple and powerful method to control UPS inverter applications with output LC filter, Saudi International Electronics, Communications and Photonics Conference (SIECPC'13), pp.1-6, 2013. ,
Model predictive control of an inverter with output LC filter for UPS applications, IEEE Trans. Ind. Electron, vol.56, pp.1875-1883, 2009. ,
Pulsewidth modulation electronic power conversion, Proc.IEEE, vol.82, pp.1194-1214, 1994. ,
, , 1995.
Deadbeat control of a three-phase inverter with an output LC filter, IEEE Trans. Power Electron, vol.11, pp.16-23, 1996. ,
Novel vector control system using deadbeat-controlled PWM inverter with output LC filter, IEEE Trans. Ind. Appl, vol.40, pp.162-169, 2004. ,
An improved deadbeat control for UPS using disturbance observers, IEEE Trans. Ind. Electron, vol.52, pp.206-212, 2005. ,
A comparative analysis of multiloop voltage regulation strategies for single and three-phase UPS systems, IEEE Trans. Power Electron, vol.18, pp.1176-1185, 2003. ,
Analysis of multiloop strategies for LC/CL/LCLfiltered voltage-source and current-source inverters, IEEE Trans. Ind. Appl, vol.41, pp.644-654, 2005. ,
Uninterruptible power supply multiloop control employing digital predictive voltage and current regulators, IEEE Trans. Ind. Appl, vol.37, pp.1846-1854, 2001. ,
Stationary frame voltage harmonic controller for standalone power generation, Proc. Eur. Conf. Power Electron. Appl, pp.1-10, 2007. ,
Control of distributed generation systems-part I: Voltages and currents control, IEEE Trans. Power Electron, vol.19, pp.1541-1550, 2004. ,
Repetitive based controller for a UPS inverter to compensate unbalance and harmonic distortion, IEEE Trans. Ind. Electron, vol.54, pp.504-510, 2007. ,
Multiple-loop H-infinity control design for uninterruptible power supplies, IEEE Trans. Ind. Electron, vol.54, pp.1591-1602, 2007. ,
Predictive control in power electronics and drives, IEEE Trans. Ind. Electron, vol.55, 2008. ,
An improved robust predictive current regulation algorithm, IEEE Trans. Ind. Appl, vol.41, pp.1720-1733, 2005. ,
A deadbeat current controller for field oriented induction motor drives, IEEE Trans. Power Electron, vol.17, pp.772-778, 2002. ,
Robust dead-beat current control for PWM rectifier and active filters, IEEE Trans. Ind. Appl, vol.23, pp.613-620, 1999. ,
A controller architecture for high bandwidth active power filters, IEEE Trans. Power Electron, vol.18, pp.317-325, 2003. ,
Predictive digital control of power factor preregulators with input voltage estimation using disturbance observers, IEEE Trans. Power Electron, vol.20, pp.140-147, 2005. ,
Digital control of three-phase series-parallel uninterruptible power supply systems, IEEE Trans. Power Electron, vol.22, pp.1116-1127, 2007. ,
Digital deadbeat control tuning for dc-dc converters using error correlation, IEEE Trans. power. Electron, vol.22, pp.1566-1570, 2007. ,
Model predictive control for electrical drives, Proc. IEEE PESC, pp.1793-1799, 2005. ,
, Model Predictive Control, 2007.
Predictive Control With Constraints, 2001. ,
Performance evaluation of model predictive direct torque control, Proc. IEEE PESC, pp.4737-4744, 2008. ,
, Texas instruments
An Introduction to Digital Signal Processors, 2002. ,
From chips to systems: An introduction to microprocessors, Sybex, 1987. ,
Using TMS320 family DSPs in motion control systems, First European DSP Education and Research Conference, 1996. ,
, Berkeley design technology, inc
, Choosing a DSP Processor, 2000.
TI DSP products: Making innovation possible. Texas Instruments, 2007. ,
TMS320 family of digital signal processors, Proceedings Of The IEEE, vol.2, pp.1143-1159, 1987. ,
Computer Controlled Systems, 1984. ,
Digital control applications with the TMS320 family -selected application notes, Digital Signal Processing Products, 1991. ,
Enhanced control of an AC motor using fuzzy logic and a TMS320 digital processor, 1996. ,
Digital control of AC induction motors using TMS320 DSP family, 1995. ,
Microcomputer control of power electronics and drives, 1987. ,
Design of active noise control systems with the TMS320 family, Digital Signal Processing Solution, 1996. ,
Signal Controllers (DSCs) data manual, Texas Instruments, Tech. Rep, 2010. ,
Signal Controllers (DSCs) data manual, Texas Instruments, Tech. Rep, 2012. ,
Comparison of dierent filter types for grid connected inverter, Progress In Electromagnetics Research Symposium Proceedings PIERS, pp.1426-1429, 2011. ,
Classical methods and model predictive control of three-phase inverter with output LC filter for UPS applications, IEEE International Conference on Control, Decision and Information Technologies (CoDIT'13), pp.6-8, 2013. ,
Automatische Regelsystem mit veranderlicher struktur automatic control systems with variable structure, 2003. ,
Direkte drehmomentregelung von drehstromantrieben (direct torque control of three-phase drives), ABB Technik, vol.3, pp.19-24, 1995. ,
A new quick response and high efficiency control strategy of an induction motor, IEEE IAS Annual Meeting, pp.496-507, 1985. ,
A predictive controller for the stator current vector of AC machines fed from a switched voltage source, International Power Electronics Conference IPEC, vol.2, pp.1665-1675, 1983. ,
A new fast responce current control scheme for line controlled converters, International Semiconductor Power Converter Conference, pp.175-183, 1982. ,
Multilevel hystersis comparator forms for direct torque control schemes, Electronic Letters, vol.34, issue.6, pp.601-603, 1998. ,
Direkte Regelung des Drehmomentmittelwerts einer Induktions-Machine direct control of the mean torque value of an induction motor, 1999. ,
Discrete-time current control of voltage-fed three-phase PWM inverters, IEEE Trans. Ind. Electron, vol.11, pp.260-269, 1996. ,
Direct self-control (DSC) of inverter-fed induction machine, IEEE Trans. Power Electron, vol.3, pp.420-429, 1988. ,
Direct mean torque control of an induction motor, Proc. Conf. Rec. EPE, vol.3, pp.672-677, 1997. ,
Automatic control systems with variable structure (automatische regelsystem mit veranderlicher struktur), 1969. ,
A new quick response and high efficiency control strategy of an induction motor, Conf. Rec. IEEE IAS Annu. Meeting, pp.1665-1675, 1985. ,
A new speed-control method for induction motors, Proc. Conf. Rec. PCIM, pp.131-136, 1998. ,
An advanced SVPWM-based predictive current controller for three-phase inverters in distributed generation systems, IEEE Trans. Ind. Electron, vol.55, pp.1235-1246, 2008. ,
A predictive instantaneous-current PWM controlled rectifier with AC-side harmonic current reduction, IEEE Trans. Ind. Electron, vol.44, pp.337-343, 1997. ,
DSP-based active power filter with predictive current control, IEEE Trans. Ind. Electron, vol.44, pp.329-336, 1997. ,
Analysis and implementation of a new PFC digital control method, Proc. Conf. Rec. PESC, 2003. ,
Predictive digital control of power factor preregulators, Proc. Conf. Rec. PESC, 2003. ,
Uninterruptible power supply multiloop employing digital predictive voltage and current regulators, IEEE Trans. Ind. Appl, vol.37, pp.1846-1854, 2001. ,
Digital deadbeat control tuning for dc-dc converters using error correlation, IEEE Trans. Power Electron, vol.22, pp.1566-1570, 2007. ,
Predictive torque control for inverter-fed induction machines, IEEE Trans. Ind. Electron, vol.54, pp.1073-1079, 2007. ,
Practical issues with predictive current controllers, Proc. Australasian Univ. Power Eng. Conf., (, 2001. ,
Predictive current control of voltage source inverters, IEEE Trans. Ind. Electron, vol.51, pp.585-593, 2004. ,
An improved deadbeat current control scheme with a novel adaptive self-tuning load model for a three-phase PWM voltage-source inverter, IEEE Trans. Ind. Electron, vol.54, pp.747-759, 2007. ,
Robust high bandwidth discrete-time predictive current control with predictive internal model -a unified approach for voltage-source PWM converters, IEEE Trans. Power Electron, vol.23, pp.126-136, 2008. ,
Adaptive discrete-time gridvoltage sensorless interfacing scheme for grid-connected DG-inverters based on neuralnetwork identification and deadbeat current regulation, IEEE Trans. Power Electron, vol.23, pp.308-321, 2008. ,
Predictive current control for multilevel active rectifiers with reduced switching frequency, IEEE Trans. Ind. Electron, vol.55, pp.163-172, 2008. ,
Adaptive predictive control, Annual Review in Automatic Programming, vol.20, pp.83-94, 1996. ,
Generalized predictive control. part I. the basic algorithm, Automatica, vol.23, issue.2, pp.137-148, 1987. ,
Generalized predictive control. part II. extensions and interpretations, Automatica, vol.23, issue.2, pp.149-160, 1987. ,
Robust self-tuning control of AC servo drive, Conf. Record EPE'91, vol.3, pp.48-49, 1991. ,
Direct control of induction motor currents, European Conference on Power Electronics and Applications EPE 1985, vol.2, pp.3-7, 1985. ,
Direct flux control of induction motor drives, European Conference on Power Electronics and Applications EPE, 2001. ,
Direkte selbstregelung (DSR) fur hochdynamische drehfelantriebe mit stromrichterspeisung (direct self control for inverter supplied high dynamic AC drives), vol.7, pp.211-218, 1985. ,
Verfahren zur direkten regelung der geschwindigkeiteines elekrischen antriebs(principle for direct control of the speed of an electric drive), DE, vol.196, pp.35-981 ,
Generalized predictive control (GPC)-ready for use in drive applications, 32nd IEEE Power Electronics Specialists Conference pres2001, vol.4, pp.1839-1844, 2001. ,
Constrained Control and Estimation -An Optimization Perspective, 2005. ,
A survey of industrial model predictive control technology, Control Eng. Pract, vol.11, pp.733-764, 2003. ,
Constrained model predictive control: Optimality and stability, Automatica, vol.36, pp.789-814, 2000. ,
Model predictive control: Theory and practice -a survey, Automatica, vol.25, pp.335-348, 1989. ,
Constrained Control and Estimation, 2004. ,
Control of a hybrid a symmetric multilevel inverter for competitive medium-voltage industrial drives, IEEE Trans. Ind. Appl, vol.41, pp.655-664, 2005. ,
Predictive control of a three-phase inverter, Electron. Lett, vol.40, pp.561-562, 2004. ,
Direct power control of an AFE using predictive control, IEEE Trans. Power Electron, vol.23, pp.2516-2523, 2008. ,
Predictive control algorithm technique for multilevel a symmetric cascaded h-bridge inverters, IEEE Trans. Ind. Electron, vol.55, pp.4354-4361, 2008. ,
Predictive control of a three-phase UPS inverter using two steps prediction horizon, IEEE International Conference on Industrial Technology (ICIT), pp.1283-1288, 2010. ,
An improved dynamic response of voltage source inverter using novel hysteresis dead band current controller, 18th Annual Symposium on Emerging Needs in Computing, 2009. ,
, Hardware in the loop from the matlab/simulink environment, 2013.
On hardware-in-the-loop simulation, 44th IEEE Conference on Decision and Control, 2005 and 2005 European Control Conference CDC-ECC05, pp.3194-3198, 2005. ,
A low-cost real-time hardware-inthe-loop testing approach of power electronics controls, IEEE Transactions on Industrial Electronics, vol.54, issue.2, pp.919-931, 2007. ,
, ezdsp T M for the TMS320F28335DSP controller, 2014.
