New interface
Journal articles
Convergence and quasi-optimal cost of adaptive algorithms for nonlinear operators including iterative linearization and algebraic solver
Abstract : We consider a second-order elliptic boundary value problem with strongly monotone and Lipschitz-continuous nonlinearity. We design and study its adaptive numerical approximation interconnecting a finite element discretization, the Banach-Picard linearization, and a contractive linear algebraic solver. We in particular identify stopping criteria for the algebraic solver that on the one hand do not request an overly tight tolerance but on the other hand are sufficient for the inexact (perturbed) Banach-Picard linearization to remain contractive. Similarly, we identify suitable stopping criteria for the Banach-Picard iteration that leave an amount of linearization error that is not harmful for the residual a posteriori error estimate to steer reliably the adaptive mesh-refinement. For the resulting algorithm, we prove a contraction of the (doubly) inexact iterates after some amount of steps of mesh-refinement/linerization/algebraic solver, leading to its linear convergence. Moreover, for usual mesh-refinement rules, we also prove that the overall error decays at the optimal rate with respect to the number of elements (degrees of freedom) added with respect to the initial mesh. Finally, we prove that our fully adaptive algorithm drives the overall error down with the same optimal rate also with respect to the overall algorithmic cost expressed as the cumulated sum of the number of mesh elements over all mesh-refinement, linearization, and algebraic solver steps. Numerical experiments support these theoretical findings and illustrate the optimal overall algorithmic cost of the fully adaptive algorithm on several test cases.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-02557718
Contributor : Martin Vohralik Connect in order to contact the contributor
Submitted on : Monday, November 22, 2021 - 11:34:10 AM
Last modification on : Tuesday, August 2, 2022 - 4:25:04 AM
File
inex_Newt_opt_cost_HAL.pdf
Identifiers
Citation
Alexander Haberl, Dirk Praetorius, Stefan Schimanko, Martin Vohralík. Convergence and quasi-optimal cost of adaptive algorithms for nonlinear operators including iterative linearization and algebraic solver. Numerische Mathematik, 2021, 147 (3), pp.679-725. ⟨10.1007/s00211-021-01176-w⟩. ⟨hal-02557718v2⟩
Share
Metrics
Record views
140
Files downloads
91
