Towards objective probabilistic climate forecasting, Nature, vol.419, issue.6903, pp.228-228, 2002. ,
A Monte Carlo implementation of the nonlinear filtering problem to produce ensemble assimilations and forecasts, Monthly Weather Review, vol.127, issue.12, pp.2741-2758, 1999. ,
A method for producing and evaluating probabilistic forecasts from ensemble model integrations, Journal of Climate, vol.9, issue.7, pp.1518-1530, 1996. ,
Random-forcing model of the mesoscale oceanic eddies, Journal of Fluid Mechanics, vol.529, pp.71-95, 2005. ,
Material transport in oceanic gyres. part II: Hierarchy of stochastic models, Journal of Physical Oceanography, vol.32, issue.3, pp.797-830, 2002. ,
A spectral stochastic kinetic energy backscatter scheme and its impact on flow-dependent predictability in the ECMWF ensemble prediction system, Journal of the Atmospheric Sciences, vol.66, issue.3, pp.603-626, 2009. ,
Model uncertainty in a mesoscale ensemble prediction system: Stochastic versus multiphysics representations, Monthly Weather Review, vol.139, issue.6, pp.1972-1995, 2011. ,
Stochastic parameterization: towards a new view of weather and climate models, Tech. rep, 2015. ,
Uniform potential vorticity flow: part I. theory of wave interactions and two-dimensional turbulence, Journal of the Atmospheric Sciences, vol.35, issue.5, pp.774-783, 1978. ,
An iterative ensemble kalman smoother, Quarterly Journal of the Royal Meteorological Society, vol.140, issue.682, pp.1521-1535, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00947740
Essai sur la théorie des eaux courantes. Mémoires présentés par divers savantsà l'Académie des Sciences, vol.23, pp.1-680, 1877. ,
Impact of uncertainties in the horizontal density gradient upon low resolution global ocean modeling, Ocean Modelling, vol.66, pp.64-76, 2013. ,
Stochastic partial differential equations and turbulence, Mathematical Models and Methods in Applied Sciences, vol.1, issue.01, pp.41-59, 1991. ,
Ensemble-derived stationary and flow-dependent background-error covariances: Evaluation in a quasi-operational nwp setting, Quarterly Journal of the Royal Meteorological Society, vol.131, issue.607, pp.1013-1043, 2005. ,
Representing model uncertainty for climate forecasts, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
Weather prediction in a world of uncertainties: should ensembles simulate the effect of model approximations?, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
Stochastic representation of model uncertainties in the ECMWF ensemble prediction system, Quarterly Journal Royal Meteorological Society, vol.125, pp.2887-2908, 1999. ,
Motion estimation under location uncertainty for turbulent fluid flows, Experiments in Fluids, vol.59, issue.1, p.8, 2018. ,
Bayesian signal processing: Classical, modern and particle filtering methods, vol.54, 2011. ,
Surface kinetic energy transfer in surface quasi-geostrophic flows, J Fluid Mech, vol.604, pp.165-174, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00400436
Coarse large-eddy simulations in a transitional wake flow with flow models under location uncertainty, Computers & Fluids, vol.168, pp.170-189, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01764616
Deciphering the role of small-scale inhomogeneity on flow structuration: a stochastic approach, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02398521
Large-scale flows under location uncertainty: a consistent stochastic framework, Quarterly Journal of the Royal Meteorological Society, vol.144, issue.710, pp.251-260, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01629898
Simulation of the Kolmogorov inertial subrange using an improved subgrid model, Physics of Fluids A: Fluid Dynamics, vol.3, issue.1, pp.188-200, 1989. ,
Predicting stochastic systems by noise sampling, and application to the el niño-southern oscillation, Proceedings of the National Academy of Sciences, vol.108, issue.29, pp.11766-11771, 2011. ,
The emergence of fast oscillations in a reduced primitive equation model and its implications for closure theories, Computers & Fluids, vol.151, pp.3-22, 2017. ,
Pseudo-stochastic simulation of turbulent channel flows with near-wall modelling, Mémin E, 2014. ,
Stochastic modelling of turbulent flows for numerical simulations, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02044809
Stochastic partial differential fluid equations as a diffusive limit of deterministic lagrangian multi-time dynamics, 2017. ,
Modelling uncertainty using circulation-preserving stochastic transport noise in a 2-layer quasi-geostrophic model, 2018. ,
Sequential monte carlo for stochastic advection by lie transport, 2018. ,
, Numerically modelling stochastic lie transport in fluid dynamics, 2018.
Reports from working group 1 : What are the sources of model error and how can we improve the physical basis of model uncertainty representation?, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
Solution properties of a 3d stochastic euler fluid equation, 2017. ,
Diagnosis of observation, background and analysis-error statistics in observation space, Stochastic Equations in Infinite Dimensions. Encyclopedia of Mathematics and its Applications, vol.131, pp.3385-3396, 1992. ,
A tutorial on particle filtering and smoothing: Fifteen years later, Handbook of Nonlinear Filtering, vol.12, pp.656-704, 2009. ,
Stochastic theory of compressible turbulent fluid transport, Springer Dukowicz JK, Smith RD, vol.9, issue.11, pp.3523-3529, 1997. ,
Energetically consistent scale adaptive stochastic and deterministic energy backscatter schemes for an atmospheric model, Quarterly Journal of the Royal Meteorological Society, 2019. ,
Predicting the uncertainty of numerical weather forecasts: A review, METEOROLOGISCHE ZEITSCHRIFT-BERLIN, vol.6, pp.147-183, 1997. ,
Particles and fields in fluid turbulence, Reviews of modern Physics, vol.73, issue.4, p.913, 2001. ,
, Statistical state dynamics: a new perspective on turbulence in shear flow, 2014.
Suppression of eddy diffusivity across jets in the Southern Ocean, Journal of Physical Oceanography, vol.40, issue.7, pp.1501-1519, 2010. ,
The interaction between noise and transport mechanisms in PDEs, Milan Journal of Mathematics, vol.79, issue.2, pp.543-560, 2011. ,
Stochastic homogenization for an energy conserving multiscale toy model of the atmosphere, Physica D: Nonlinear Phenomena, vol.254, pp.46-56, 2013. ,
Low-order stochastic mode reduction for a realistic barotropic model climate, Journal of the atmospheric sciences, vol.62, issue.6, pp.1722-1745, 2005. ,
Stochastic climate theory and modeling, Wiley Interdisciplinary Reviews: Climate Change, vol.6, issue.1, pp.63-78, 2015. ,
Extremes in dynamic-stochastic systems, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.27, issue.1, p.12101, 2017. ,
Subgrid-scale parameterizations of eddy-topographic force, eddy viscosity, and stochastic backscatter for flow over topography, Journal of the atmospheric sciences, vol.56, issue.11, pp.1481-1494, 1999. ,
Turbulence: the legacy of AN Kolmogorov, Physical review letters, vol.75, issue.21, p.3834, 1995. ,
Stochastic geometric models with non-stationary spatial correlations in lagrangian fluid flows, Journal of nonlinear science, vol.28, issue.3, pp.873-904, 2018. ,
Isopycnal mixing in ocean circulation models, Journal of Physical Oceanography, vol.20, issue.1, pp.150-155, 1990. ,
A dynamic subgrid-scale eddy viscosity model, Phys of Fluids, vol.3, pp.1760-1765, 1991. ,
Extracting macroscopic dynamics: model problems and algorithms, Nonlinearity, vol.17, issue.6, p.55, 2004. ,
Strictly proper scoring rules, prediction, and estimation, Journal of the American Statistical Association, vol.102, issue.477, pp.359-378, 2007. ,
Calibrated probabilistic forecasting using ensemble model output statistics and minimum crps estimation, Monthly Weather Review, vol.133, issue.5, pp.1098-1118, 2005. ,
The role of additive and multiplicative noise in filtering complex dynamical systems, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Science, vol.469, p.20130096, 2013. ,
Homogenization for deterministic maps and multiplicative noise, Proceedings of the Royal Society of London A: Mathematical, Physical and Engineering Sciences, vol.469, 2013. ,
Stochastic climate theory, Nonlinear and Stochastic Climate Dynamics, 2015. ,
The continuous ranked probability score for circular variables and its application to mesoscale forecast ensemble verification, Quarterly Journal of the Royal Meteorological Society: A journal of the atmospheric sciences, vol.132, issue.621C, pp.2925-2942, 2006. ,
Stochastic superparameterization in quasigeostrophic turbulence, Journal of Computational Physics, vol.271, pp.78-98, 2014. ,
219) Numerical development and evaluation of an energy conserving conceptual stochastic climate model. Mathematics of climate and weather forecasting In press ,
Gulf stream dynamics along the southeastern us seaboard, Journal of Physical Oceanography, vol.45, issue.3, pp.690-715, 2015. ,
Interpretation of rank histograms for verifying ensemble forecasts, Monthly Weather Review, vol.129, issue.3, pp.550-560, 2001. ,
Verification of eta-rsm short-range ensemble forecasts, Monthly Weather Review, vol.125, issue.6, pp.1312-1327, 1997. ,
Stochastic representation of the reynolds transport theorem: revisiting large-scale modeling, Computers & Fluids, vol.156, pp.456-469, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01394780
Stochastic climate models. part I: theory, Tellus, vol.28, pp.473-485, 1976. ,
Surface quasi-geostrophic dynamics, Journal of Fluid Mechanics, vol.282, pp.1-20, 1995. ,
Decomposition of the continuous ranked probability score for ensemble prediction systems, Weather and Forecasting, vol.15, issue.5, pp.559-570, 2000. ,
Variational principles for stochastic fluid dynamics, Proceedings of the Royal Society of London A: Mathematical, Physical and Engineering Sciences, vol.471, 2015. ,
Turbulence, coherence structures, dynamical systems and symetry, 1996. ,
Stochastic mode-reduction in models with conservative fast sub-systems, 2014. ,
Parameterizing subgrid-scale eddy effects using energetically consistent backscatter, Ocean Modelling, vol.80, pp.36-48, 2014. ,
Facets of forecast evaluation, 2016. ,
Diagnosing lateral mixing in the upper ocean with virtual tracers: Spatial and temporal resolution dependence, Journal of Physical Oceanography, vol.41, issue.8, pp.1512-1534, 2011. ,
New methods for estimating ocean eddy heat transport using satellite altimetry, Monthly Weather Review, vol.140, issue.5, pp.1703-1722, 2012. ,
Upper ocean turbulence from high-resolution 3D simulations, Journal of Physical Oceanography, vol.38, issue.8, pp.1748-1763, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00400075
Stochastic equations through the eye of the physicist: Basic concepts, exact results and asymptotic approximations, 2005. ,
Short-time correlation approximations for diffusing tracers in random velocity fields: A functional approach, Stochastic modelling in physical oceanography, pp.221-269, 1996. ,
Stochastic modeling of decadal variability in ocean gyres, Geophysical Research Letters, vol.42, issue.5, pp.1543-1553, 2015. ,
Data-driven non-markovian closure models, Physica D: Nonlinear Phenomena, vol.297, pp.33-55, 2015. ,
Small-scale structure of a scalar field convected by turbulence, Physics of Fluids, vol.11, issue.5, pp.945-953, 1958. ,
Anomalous scaling of a randomly advected passive scalar, Physical review letters, vol.72, issue.7, p.1016, 1994. ,
, Stochastic flows and stochastic differential equations, vol.24, 1997.
A limit theorem for perturbed operator semigroups with applications to random evolutions, Journal of Functional Analysis, vol.12, issue.1, pp.55-67, 1973. ,
Verification tools for probabilistic forecasts of continuous hydrological variables, Hydrology and Earth System Sciences, vol.11, issue.4, pp.1267-1277, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00305072
Surface quasi-geostrophy, Fluids, vol.2, issue.1, p.7, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01476001
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.38, issue.2, pp.97-110, 1986. ,
A stochastic projection method for fluid flow. II. random process, Journal of Computational Physics, vol.181, pp.9-44, 2002. ,
Atmospheric predictability and two-dimensional turbulence, Journal of the Atmospheric Sciences, vol.28, issue.2, pp.145-161, 1971. ,
Stochastic backscatter in a subgrid-scale model: Plane shear mixing layer, Physics of Fluids A: Fluid Dynamics, vol.2, issue.3, pp.297-299, 1989. ,
Stochastic representations of model uncertainties in the ifs, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
On the application of the eddy viscosity concept in the inertial subrange of turbulence, vol.123, 1966. ,
Fractional brownian motion, the Matérn process, and stochastic modeling of turbulent dispersion, Nonlinear Processes in Geophysics, vol.24, issue.1, pp.481-514, 2017. ,
Generalized whittle-matérn random field as a model of correlated fluctuations, Journal of Physics A: Mathematical and Theoretical, vol.42, issue.10, p.105202, 2009. ,
An ensemble-based four-dimensional variational data assimilation scheme. part ii: Observing system simulation experiments with advanced research wrf (arw), Monthly Weather Review, vol.137, issue.5, pp.1687-1704, 2009. ,
The predictability of a flow which possesses many scales of motion, Tellus, vol.21, pp.289-307, 1969. ,
Data-based stochastic model reduction for the kuramotosivashinsky equation, Physica D: Nonlinear Phenomena, vol.340, pp.46-57, 2017. ,
Mathematical and physical ideas for climate science, Reviews of Geophysics, vol.52, issue.4, pp.809-859, 2014. ,
Statistical energy conservation principle for inhomogeneous turbulent dynamical systems, Proceedings of the National Academy of Sciences, vol.112, issue.29, pp.8937-8941, 2015. ,
Models for stochastic climate prediction. Proceedings of the National Academy of, Sciences, vol.96, issue.26, pp.14687-14691, 1999. ,
Vanden Eijnden E (2001) A mathematical framework for stochastic climate models, Communications on Pure and Applied Mathematics, vol.54, issue.8, pp.891-974 ,
An applied mathematics perspective on stochastic modelling for climate, Philosophical Transactions of the Royal Society of London A: Mathematical, Physical and Engineering Sciences, vol.366, pp.2427-2453, 1875. ,
Toward a stochastic parameterization of ocean mesoscale eddies, Ocean Modelling, vol.79, pp.1-20, 2014. ,
Scoring rules for continuous probability distributions, Management science, vol.22, issue.10, pp.1087-1096, 1976. ,
Representing model error in the met office convection permitting ensemble predicion system, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
Fluid flow dynamics under location uncertainty, Geophysical & Astrophysical Fluid Dynamics, vol.108, issue.2, pp.119-146, 2014. ,
Statistical predictability of decaying turbulence, Journal of the atmospheric sciences, vol.43, issue.9, pp.857-870, 1986. ,
Estimating deformations of random processes for correlation modelling in a limited area model, Quarterly Journal of the Royal Meteorological Society, vol.139, issue.671, pp.534-547, 2013. ,
Estimating deformations of random processes for correlation modelling: methodology and the one-dimensional case, Quarterly Journal of the Royal Meteorological Society, vol.139, issue.672, pp.771-783, 2013. ,
Stochastic Navier-Stokes equations for turbulent flows, SIAM Journal on Mathematical Analysis, vol.35, issue.5, pp.1250-1310, 2004. ,
Data assimilation in slow-fast systems using homogenized climate models, Journal of the atmospheric sciences, vol.69, issue.4, pp.1359-1377, 2012. ,
Wellposedness for stochastic continuity equations with ladyzhenskaya-prodi-serrin condition, Nonlinear Differential Equations and Applications NoDEA, vol.22, issue.5, pp.1247-1258, 2015. ,
The role of model dynamics in ensemble Kalman filter performance for chaotic systems, Tellus A, vol.63, issue.5, pp.958-977, 2011. ,
Analytical theories of turbulence, Journal of Fluid Mechanics, vol.41, issue.02, pp.363-386, 1970. ,
Estimation of the local diffusion tensor and normalization for heterogeneous correlation modelling using a diffusion equation, Quarterly Journal of the Royal Meteorological Society, vol.134, issue.635, pp.1425-1438, 2008. ,
URL : https://hal.archives-ouvertes.fr/meteo-00359244
Modelling of local length-scale dynamics and isotropizing deformations, Quarterly Journal of the Royal Meteorological Society, vol.140, issue.681, pp.1387-1398, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-02101388
Data assimilation with the weighted ensemble Kalman filter, Tellus A, vol.62, issue.5, pp.673-697, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00490840
Asymptotic theory of mixing stochastic ordinary differential equations, Communications on Pure and Applied Mathematics, vol.27, issue.5, pp.641-668, 1974. ,
On estimation of a probability density function and mode. The annals of mathematical statistics, vol.33, pp.1065-1076, 1962. ,
Systematic physics constrained parameter estimation of stochastic differential equations, Computational Statistics & Data Analysis, vol.83, pp.182-199, 2015. ,
Stochastic parametrization development in the noaa/ncep global forecast system, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
Noise out of chaos and why it won't go away, Bulletin of the American Meteorological Society, vol.84, issue.7, p.921, 2003. ,
A stochastic approach to nonlinear dynamics: A review (extended version of the article-" noise out of chaos and why it won't go away"), Bulletin of the American Meteorological Society, vol.84, issue.7, pp.925-925, 2003. ,
A balance condition for stochastic numerical models with application to the El Nino-southern oscillation, Journal of climate, vol.7, issue.9, pp.1352-1372, 1994. ,
The optimal growth of tropical sea surface temperature anomalies, Journal of climate, vol.8, issue.8, pp.1999-2024, 1995. ,
Stochastic flow approach to model the mean velocity profile of wall-bounded flows, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01947662
A stochastic parameterization for deep convection based on equilibrium statistics, Journal of the Atmospheric Sciences, vol.65, issue.1, pp.87-105, 2008. ,
A lagrangian two-time probability density function equation for inhomogeneous turbulent flows, The Physics of fluids, vol.26, issue.12, pp.3448-3450, 1983. ,
Lagrangian PDF methods for turbulent flows, Annu Rev Fluid Mech, vol.26, pp.23-63, 1994. ,
The velocity-dissipation probability density function model for turbulent flows, Physics of Fluids A: Fluid Dynamics, vol.2, issue.8, pp.1437-1449, 1990. ,
, A concise course on stochastic partial differential equations, 1905.
Model error representation in meteo france ensemble nwp system, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
Mixing and fluid dynamics under location uncertainty, 2017. ,
URL : https://hal.archives-ouvertes.fr/tel-01507292
Reduced flow models from a stochastic Navier-Stokes representation, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01215301
Geophysical flows under location uncertainty, part I: Random transport and general models, Geophysical & Astrophysical Fluid Dynamics, vol.111, issue.3, pp.149-176, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01391420
Geophysical flows under location uncertainty, part II: Quasi-geostrophic models and efficient ensemble spreading, Geophysical & Astrophysical Fluid Dynamics, vol.111, issue.3, pp.177-208, 2017. ,
Stochastic modelling and diffusion modes for POD models and small-scale flow analysis, 2017. ,
Data-driven versus self-similar parameterizations for stochastic lie transport and location uncertainty Submitted, 2019. ,
Reports from working group 3 : What are the pros/cons of existing model uncertainty schemes and how should these be measured?, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
Remarks on some nonparametric estimates of a density function, The Annals of Mathematical Statistics, vol.27, issue.3, pp.832-837, 1956. ,
Attractor local dimensionality, nonlinear energy transfers and finite-time instabilities in unstable dynamical systems with applications to two-dimensional fluid flows, Proceedings of the Royal Society of London A: Mathematical, Physical and Engineering Sciences, vol.469, 2013. ,
Dynamical criteria for the evolution of the stochastic dimensionality in flows with uncertainty, Physica D: Nonlinear Phenomena, vol.241, issue.1, pp.60-76, 2012. ,
Blending modified Gaussian closure and non-Gaussian reduced subspace methods for turbulent dynamical systems, Journal of Nonlinear Science, vol.23, issue.6, pp.1039-1071, 2013. ,
Statistically accurate low-order models for uncertainty quantification in turbulent dynamical systems, Proceedings of the National Academy of Sciences, vol.110, issue.34, pp.13705-13710, 2013. ,
A statistically accurate modified quasilinear Gaussian closure for uncertainty quantification in turbulent dynamical systems, Physica D: Nonlinear Phenomena, vol.252, pp.34-45, 2013. ,
Reconciling non-gaussian climate statistics with linear dynamics, Journal of Climate, vol.22, issue.5, pp.1193-1207, 2009. ,
Need for caution in interpreting extreme weather statistics, Journal of Climate, vol.28, issue.23, pp.9166-9187, 2015. ,
Reynolds number effects in lagrangian stochastic models of turbulent dispersion, Physics of Fluids A: Fluid Dynamics, vol.3, issue.6, pp.1577-1586, 1991. ,
Variogram-based proper scoring rules for probabilistic forecasts of multivariate quantities, Monthly Weather Review, vol.143, issue.4, pp.1321-1334, 2015. ,
Stochastic backscatter of turbulence energy and scalar variance by random subgrid-scale fluxes, Proceedings of the Royal Society of London A: Mathematical, vol.451, pp.293-318, 1995. ,
Model error representation in the canadian ensemble prediction systems, ECMWF/WWRP Workshop: Model Uncertainty, 2016. ,
A kinetic energy backscatter algorithm for use in ensemble prediction systems, Quarterly Journal of the Royal Meteorological Society, vol.612, pp.3079-3012, 2005. ,
A stochastic convective backscatter scheme for use in ensemble prediction systems, Quarterly Journal of the Royal Meteorological Society, vol.141, issue.692, pp.2602-2616, 2015. ,
General circulation experiments with the primitive equation: I. the basic experiment, Monthly Weather Review, vol.91, pp.99-165, 1963. ,
Performance bounds for particle filters using the optimal proposal, Monthly Weather Review, vol.143, pp.4750-4761, 2015. ,
Evaluation of probabilistic prediction systems, Workshop proceedings" Workshop on predictability, pp.20-22, 1997. ,
Joint estimation of model and observation error covariance matrices in data assimilation: a review, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01867958
Verification: assessment of calibration and Trevisan A, Palatella L (2011) On the Kalman filter error covariance collapse into the unstable subspace, Nonlinear Processes in Geophysics, vol.18, issue.2, pp.243-250, 2017. ,
Assimilation of standard and targeted observations within the unstable subspace of the observation-analysis-forecast cycle system, Journal of the atmospheric sciences, vol.61, issue.1, pp.103-113, 2004. ,
Atmospheric and oceanic fluid dynamics: fundamentals and large-scale circulation, 2006. ,
Oceanic turbulence and stochastic models from subsurface Lagrangian data for the Northwest Atlantic Ocean, Journal of physical oceanography, vol.34, issue.8, pp.1884-1906, 2004. ,
Gaussian processes for machine learning. the, vol.2, p.4, 2006. ,
Stochastic model reduction for slow-fast systems with moderate time-scale separation, 2018. ,
Disentangling multi-level systems: averaging, correlations and memory, Journal of Statistical Mechanics: Theory and Experiment, vol.2012, issue.03, p.3003, 2012. ,
Study of variational ensemble methods for image assimilation, Rennes, vol.1, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-01140384
High-resolution data assimilation through stochastic subgrid tensor and parameter estimation from 4denvar, Tellus A: Dynamic Meteorology and Oceanography, vol.69, p.1308772, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01500140
Estimation of physical parameters under location uncertainty using an ensemble 2-expectation-maximization algorithm, Quarterly Journal of the Royal Meteorological Society, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01944730
