, Sparse and Redundant Representations, 2010.
URL : https://hal.archives-ouvertes.fr/inria-00568893
Dictionaries for sparse representation modeling, Proceedings of the IEEE, vol.98, issue.6, pp.1045-1057, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00565811
Task-driven dictionary learning, IEEE Trans. on Pattern Analysis and Machine Intelligence, vol.34, issue.4, pp.791-804, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00521534
Dictionary learning for sparse representation: A novel approach, IEEE Signal Proc. Letters, vol.20, issue.12, pp.1195-1198, 2013. ,
K-SVD: An algorithm for designing overcomplete dictionaries for sparse representation, IEEE Trans. on Signal Processing, vol.54, issue.11, pp.4311-4322, 2006. ,
Method of optimal directions for frame design, Proceedings of IEEE ICASSP, vol.5, 1999. ,
Learning over-complete dictionaries based on atom-by-atom updating, IEEE Trans. on Signal Proc, vol.62, issue.4, pp.883-891, 2014. ,
Learning dictionaries with bounded self-coherence, IEEE Signal Proc. Letters, vol.19, issue.12, pp.861-864, 2012. ,
A new algorithm for learning overcomplete dictionaries, Proceedings of 21th European Signal Processing Conference (EUSIPCO 2013), 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00867093
Uncertainty principles and ideal atomic decomposition, IEEE Trans. Information Theory, vol.47, issue.7, pp.2845-2862, 2001. ,
On the conditioning of random subdictionaries, Appl. Computat. Harmon. Anal, vol.25, issue.1, pp.1-24, 2008. ,
Optimally sparse representation in general (nonorthogonal) dictionaries via 1 minimization, Proc. Nat. Aca. Sci, vol.100, issue.5, pp.2197-2202, 2003. ,
Grassmannian frames with applications to coding and communication, Applied and Computational Harmonic Analysis, vol.14, pp.257-275, 2003. ,
Projection design for statistical compressive sensing: A tight frame based approach, IEEE Transactions on Signal Processing, vol.61, issue.8, pp.2016-2029, 2013. ,
Regularized low-coherence overcomplete dictionary learning for sparse signal decomposition, Proceedings of 24th European Signal Processing Conference, 2016. ,
Learning incoherent dictionaries for sparse approximation using iterative projections and rotations, IEEE Trans. on Signal Proc, vol.61, issue.8, pp.2055-2065, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00706028
A new framework for designing incoherent sparsifying dictionaries, IEEE International Conference on Acoustics, Speech and Signal Processing, 2017. ,
Joint low mutual and average coherence dictionary learning, Proceeding of 26th European Signal Processing Conference(EUSIPCO 2018), 2018. ,
A new algorithm for dictionary learning based on convex approximation, Proceedings of the 27th European Signal Processing Conference, 2019. ,
Computational methods for sparse solution of linear inverse problems, Proceedings of the IEEE, vol.98, pp.948-958, 2010. ,
The matrix cookbook, 2008. ,
