Physical and biological satellite observations of the northwest African upwelling: Spatial extent and dynamics, IEEE Trans. Geosci. Remote Sens, vol.58, issue.2, pp.1409-1421, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02355252
Surface mixing and biological activity in the north-west African upwelling, Chaos, Interdiscipl. J. Nonlinear Sci, vol.29, issue.1, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01985164
The contribution and influence of coherent mesoscale eddies off the North-West African Upwelling on the open ocean, Proc. SIAM Conf. Math. Planet Earth (MPE), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01968851
Satellite remote sensing for an ecosystem approach to fisheries management, J. Mar. Sci., J. Conseil, vol.68, issue.4, pp.651-666, 2011. ,
URL : https://hal.archives-ouvertes.fr/ird-00576217
Edge detection algorithm for SST images, J. Atmos. Ocean. Technol, vol.9, issue.1, pp.67-80, 1992. ,
Algorithm AS 136: A K-means clustering algorithm, J. Roy. Stat. Soc. C, Appl. Statist, vol.28, issue.1, pp.100-108, 1979. ,
The global K-means clustering algorithm, Pattern Recognit, vol.36, issue.2, pp.451-461, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00321515
Mesoscale frontal structures in the canary upwelling system: New front and filament detection algorithms applied to spatial and temporal patterns, Remote Sens. Environ, vol.123, pp.339-346, 2012. ,
Identification of upwelling areas on sea surface temperature images using fuzzy clustering, Remote Sens. Environ, vol.112, issue.6, pp.2817-2823, 2008. ,
An efficient tool for automatic delimitation of moroccan coastal upwelling using SST images, IEEE Geosci. Remote Sens. Lett, vol.12, issue.4, pp.875-879, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078655
A simple and efficient approach for coarse segmentation of Moroccan coastal upwelling, Proc. 21st Eur. Signal Process. Conf. (EUSIPCO), pp.1-5, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00850445
An improved method for accurate computation of coastal upwelling index using sea surface temperature images, Proc. 9th Int. Symp. Signal, Image, Video Commun. (ISIVC), pp.76-81, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01424036
On the influence of the Earth's rotation on oceancurrents, Ark. Mat. Astron. Fys, vol.2, pp.1-53, 1905. ,
Adaptive image region-growing, IEEE Trans. Image Process, vol.3, issue.6, pp.868-872, 1994. ,
Upwelling and boundary circulation off northwest Africa as depicted by infrared and visible satellite observations, Prog. Oceanogr, vol.26, issue.4, pp.357-402, 1991. ,
Seasonal and interannual variability of coastal upwelling along northwest Africa and Portugal from 1981 to 1991, J. Geophys. Res, vol.99, issue.C7, pp.14197-14207, 1994. ,
Coastal upwelling and associated retention indices derived from satellite SST. Application to octopus vulgaris recruitment, Oceanologica Acta, vol.23, issue.4, pp.391-408, 2000. ,
Decadal changes in the Canary upwelling system as revealed by satellite observations: Their impact on productivity, J. Mar. Res, vol.63, issue.2, pp.359-379, 2005. ,
Seasonal and temporal study of the northwest African upwelling system, Int. J. Remote Sens, vol.32, issue.7, pp.1843-1859, 2011. ,
