Coordinated scheduling based on automatic neighbor beam relation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider a network with Massive Multiple Input Multiple Output (M-MIMO) base stations using a Grid of Beams (GoB) for data and control channels. 5G allows to establish interference relations between beams of neighboring cells. Such relations can be used to automatically generate a beam relation matrix, denoted as Automatic Neighbor Beam Relation (ANBR) matrix that can be very useful for optimizing different resource allocation processes. This paper shows how the ANBR matrix can be used to coordinate scheduling of neighboring cells with a small amount of information exchange. The coordination is performed by judicially muting or reducing the band-width of certain beams in the process of MultiUser (MU) Proportional Fair (PF) scheduling. Numerical results show how the coordination approach can bring about significant performance gain.
anbr-netgcoop.pdf (492.35 Ko) Télécharger le fichier
hal-02566350 , version 1 (06-05-2020)
hal-02566350 , version 2 (13-05-2020)
Marie Masson, Zwi Altman, Eitan Altman. Coordinated scheduling based on automatic neighbor beam relation. NETGCOOP 2020 - International Conference on NETwork Games, Control and Optimisation, Mar 2021, Cargèse, France. ⟨10.1007/978-3-030-87473-5_18⟩. ⟨hal-02566350v2⟩
272 Consultations
278 Téléchargements
