LPV Framework for Non-Linear Dynamic Control of Soft Robots using Finite Element Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work presents a methodology to control soft robots using a reduced order nonlinear finite element model. The Linear Parameter-Varying (LPV) framework is used both to model the robot along a prescribed trajectory and to design its control law. Model reduction algorithms along with radial basis functions network are used to identify the nonlinear behavior of the robot. Finally, the method is validated through simulation experiments.
LPV_SoRo.pdf (1.38 Mo) Télécharger le fichier
hal-02567575 , version 1 (07-05-2020)
  • HAL Id : hal-02567575 , version 1
Maxime Thieffry, Alexandre Kruszewski, Thierry-Marie Guerra, Christian Duriez. LPV Framework for Non-Linear Dynamic Control of Soft Robots using Finite Element Model. IFAC 2020 - 21rst IFAC World Congress, Jul 2020, Berlin, Germany. ⟨hal-02567575⟩
152 Consultations
246 Téléchargements
