The hidden side of the Allee effect: correlated demographic traits and extinction risk in experimental populations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Because Allee effects have major impacts on the dynamics of small populations, they are routinely included in demographic models for the evaluation of extinction risks. However, the structure of most common models implies that other demographic parameters (like the maximum growth rate) are modified by the inclusion of an Allee effect, which also affects in return the extinction risk of the population. Whether such correlations between demographic traits occur in natural populations or merely reflect a practical constraint related to model formalism is of primary importance to understand better the dynamics of small populations. We investigated this question using 20 populations of Trichogramma wasps raised under similar conditions, of which 3 were subject to an Allee effect. We showed that these 3 populations were also characterized by lower maximum growth rate and lower carrying capacity, and that their extinction probability was higher than for non-Allee populations. These results provide the first empirical demonstration of a correlation between the presence of positive density-dependence and impaired demographic performance, which increases the extinction risk of population, especially during the establishment phase.
Allee_trichogramma_final_PCI_formatted.pdf (3.72 Mo) Télécharger le fichier
hal-02570868 , version 1 (12-05-2020)
hal-02570868 , version 2 (01-10-2020)
hal-02570868 , version 3 (31-03-2021)
hal-02570868 , version 4 (20-04-2021)
  • HAL Id : hal-02570868 , version 4
Recommandation PCI
Recommandé par :
David Alonso. Allee effects under the magnifying glass.
Peer Community In Ecology. 2021-4-22
https://doi.org/10.24072/pci.ecology.100078
Elodie Vercken, Géraldine Groussier, Laurent Lamy, Ludovic Mailleret. The hidden side of the Allee effect: correlated demographic traits and extinction risk in experimental populations. 2021. ⟨hal-02570868v4⟩
445 Consultations
118 Téléchargements
