Generating Distributed Programs from Event-B Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
Distributed algorithms offer challenges in checking that they meet their specifications. Verification techniques can be extended to deal with the verification of safety properties of distributed algorithms. In this paper, we present an approach for combining correct-by-construction approaches and transformations of formal models (EVENT-B) into programs (DISTALGO) to address the design of verified distributed programs. We define a subset LB (Local EVENT-B) of the EVENT-B modelling language restricted to events modelling the classical actions of distributed programs as internal or local computations , sending messages and receiving messages. We define then transformations of the various elements of the LB language into DISTALGO programs. The general methodology consists in starting from a statement of the problem to program and then progressively producing an LB model obtained after several refinement steps of the initial LB model. The derivation of the LB model is not described in the current paper and has already been addressed in other works. The transformation of LB models into DISTALGO programs is illustrated through a simple example. The refinement process and the soundness of the transformation allow one to produce correct-by-construction distributed programs.
technicalreport.pdf (333.5 Ko) Télécharger le fichier
hal-02572971 , version 1 (14-05-2020)
  • HAL Id : hal-02572971 , version 1
Horatiu Cirstea, Alexis Grall, Dominique Méry. Generating Distributed Programs from Event-B Models. [Research Report] LORIA UMR 7503 CNRS, INRIA, Université de LORRAINE. 2020, pp.36. ⟨hal-02572971⟩
120 Consultations
130 Téléchargements
