Efficient robust digital hyperplane fitting with bounded error, Proceedings of DGCI, vol.6607, pp.223-234, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00790712
A tight bound for the delaunay triangulation of points on a polyhedron, Discrete & Computational Geometry, vol.48, pp.19-38, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00784900
A simple algorithm for homeomorphic surface reconstruction, International Journal of Computational Geometry and Applications, pp.213-222, 2000. ,
Practical Handbook of Curve Fitting, 1994. ,
The quickhull algorithm for convex hulls, ACM Trans. Math. Softw, vol.22, issue.4, pp.469-483, 1996. ,
Mesh generation and optimal triangulation, Lecture Notes Series on Computing, Computing in Euclidean Geometry, pp.47-123, 1995. ,
Incremental construction of the delaunay graph in medium dimension, Annual Symposium on Computational Geometry, pp.208-216, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00412437
, Algorithmic geometry, 1998.
Best fitting hyperplanes for classification, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.39, issue.6, pp.1076-1088, 2016. ,
, Cgal: The computational geometry algorithms library, 2019.
Circular and linear regression: Fitting circles and lines by least squares, CRC Pres, 2010. ,
Two-view geometry estimation by random sample and consensus, 2005. ,
Sur la sphère vide (1934), bulletin de l'Acadmie des Sciences de l'URSS, Classe des Sciences Mathmatiques et Naturelles ,
Curve and surface reconstruction : Algorithms with mathematical analysis, 2006. ,
Use of the hough transformation to detect lines and curves in pictures, Communications of the ACM, vol.15, pp.11-15, 1972. ,
Random sample consensus: a paradigm for model fitting with applications to image analysis and automated cartography, Communications of the ACM, vol.24, issue.6, pp.381-395, 1981. ,
, , 2003.
Machine analysis of bubble chamber pictures, International. Conference on High Energy Accelerators and Instrumentation, pp.554-556, 1959. ,
Discrete plane segmentation and estimation from a point cloud using local geometric patterns, Journal of Automation and Computing, vol.5, issue.3, pp.246-256, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00622344
Efficiently computing optimal consensus of digital line fitting, Proceedings of ICPR, pp.1064-1067, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00790826
An approach to robust clustering -application to range image segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.2, pp.430-444, 2000. ,
Properties of the delaunay triangulation, Proceedings of the thirteenth annual symposium on Computational geometry, 1997. ,
A discrete approach for decomposing noisy digital contours into arcs and segments, Proceedings of RRPR, in workshop of ACCV, vol.10117, pp.493-505, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01375089
, NIST/SEMATECH: e-Handbook of Statistical Methods, 2012.
Efficient robust digital annulus fitting with bounded error, Proceedings of DGCI, vol.7749, pp.253-264, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00827196
The upper bound theorem for polytopes: an easy proof of its asymptotic version, Computational Geometry, vol.5, pp.115-116, 1995. ,
Optimality of the delaunay triangulation in r d, Discrete and Computational Geometry, vol.12, issue.1, pp.189-202, 1994. ,
Géométrie discrète, calculs en nombre entiers et algorithmique (1991), thèse d'état ,
Least median of squares regression, Journal of the American statistical association, vol.79, issue.388, pp.871-880, 1984. ,
, Linear Models, 2016.
Principal component analysis with missing data and its application to polyhedral object modeling, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.9, pp.854-867, 1995. ,
Decomposition of a three-dimensional discrete object surface into discrete plane pieces, Algorithmica, vol.38, issue.1, pp.25-43, 2004. ,
Image registration methods: a survey, Image and Vision Computing, vol.21, issue.11, pp.977-1000, 2003. ,
Optimal consensus set for digital line and plane fitting, International Journal of Imaging Systems and Technology, vol.21, issue.1, pp.45-57, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00493415
