New interface
Conference papers
Model-Driven Engineering of Monitoring Application for Sensors and Actuators Networks
Abstract : Cyber-Physical Systems (CPSs) encompass both Information Infrastructures and networks of physical devices. Applications for monitoring them are usually implemented after the physical systems that they have to monitor: the CPS has to be running in order to monitor it. Monitoring applications define communications between the elements of those systems, and are compliant with their designs. Such applications can be complicated to develop, maintain and evolve, especially if the physical system changes. This paper brings an approach for engineering CPS monitoring applications, relying on model-driven techniques for generating a platform using the MQTT communication protocol for monitoring the CPS. First, it provides a meta-model for modeling sensors and actuators networks. Second, it introduces EMIT a monitoring platform for sensors and actuators networks. Third, it presents a transformation from models of sensors and actuators networks to automatically generate EMIT monitoring configuration. We illustrate our approach on a case study and discuss its limitations and improvement points.
Document type :
Conference papers
Complete list of metadata
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/hal-02612730
Contributor : Thibault Béziers la Fosse Connect in order to contact the contributor
Submitted on : Tuesday, September 29, 2020 - 4:09:40 PM
Last modification on : Thursday, December 1, 2022 - 11:06:09 AM
Identifiers
  • HAL Id : hal-02612730, version 2
Citation
Thibault Béziers La Fosse, Zheng Cheng, Jérôme Rocheteau, Jean-Marie Mottu. Model-Driven Engineering of Monitoring Application for Sensors and Actuators Networks. Software Engineering and Advanced Applications, Aug 2020, Portorož, Slovenia. ⟨hal-02612730v2⟩
Share
Metrics
Record views
112
Files downloads
315
