Efficient 3D Pointing Selection in Cluttered Virtual Environments
Most pointing techniques for 3D selection on spatially-immersive virtual environments rely on a ray originating at the user's hand whose direction is controlled by the hand orientation. In this paper we study the potential mismatch between visible objects (those which appear unoccluded from the user's eye position) and se-lectable objects (those which appear unoccluded from the user's hand position). We study the impact of such eye-hand visibility mismatch on selection performance, and propose a new technique for ray control which overcomes this problem. We present a controlled experiment to compare our technique with classic raycasting in selection tasks with complex 3D scenes. Our user studies demonstrate that our technique clearly outperforms raycasting selection, both in terms of speed and accuracy.
