Convergence in total variation of the Euler-Maruyama scheme applied to diffusion processes with measurable drift coefficient and additive noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2022
We are interested in the Euler-Maruyama discretization of a stochastic differential equation in dimension $d$ with constant diffusion coefficient and bounded measurable drift coefficient. In the scheme, a randomization of the time variable is used to get rid of any regularity assumption of the drift in this variable. We prove weak convergence with order $1/2$ in total variation distance. When the drift has a spatial divergence in the sense of distributions with $\rho$-th power integrable with respect to the Lebesgue measure in space uniformly in time for some $\rho \ge d$, the order of convergence at the terminal time improves to $1$ up to some logarithmic factor. In dimension $d=1$, this result is preserved when the spatial derivative of the drift is a measure in space with total mass bounded uniformly in time. We confirm our theoretical analysis by numerical experiments.
hal-02613774 , version 1 (20-05-2020)
Oumaima Bencheikh, Benjamin Jourdain. Convergence in total variation of the Euler-Maruyama scheme applied to diffusion processes with measurable drift coefficient and additive noise. SIAM Journal on Numerical Analysis, 2022, 60 (4), pp.1701-1740. ⟨hal-02613774⟩
157 Consultations
0 Téléchargements
