Contact Preserving Shape Transfer: retargeting motion from one shape to another - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Graphics Année : 2020
We present an automatic method that allows to retarget poses from a source to a target character by transferring the shape of the target character onto the desired pose of the source character. By considering shape instead of pose transfer our method allows to better preserve the contextual meaning of the source pose, typically contacts between body parts, than pose-based strategies. To this end, we propose an optimization-based method to deform the source shape in the desired pose using three main energy functions: similarity to the target shape, body part volume preservation, and collision management to preserve existing contacts and prevent penetrations. The results show that our method allows to retarget complex poses with several contacts to different morphologies, and is even able to create new contacts when morphology changes require them, such as increases in body size. To demonstrate the robustness of our approach to different types of shapes, we successfully apply it to basic and dressed human characters as well as wild animal models, without the need to adjust parameters.
ContactPreservingShapeTransfer_hal (1).pdf (5.46 Mo) Télécharger le fichier
ContactPreservingShapeTransfer_supplementary.mp4 (12.07 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-02613783 , version 1 (20-05-2020)
Jean Basset, Stefanie Wuhrer, Edmond Boyer, Franck Multon. Contact Preserving Shape Transfer: retargeting motion from one shape to another. Computers and Graphics, 2020, 89, pp.11-23. ⟨10.1016/j.cag.2020.04.002⟩. ⟨hal-02613783⟩
440 Consultations
356 Téléchargements
