Homogeneous approximation, recursive observer design, and output feedback, SIAM Journal on Control and Optimization, vol.47, pp.1814-1850, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00362707
Liapunov Functions and Stability in Control Theory, vol.267, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00139067
Robustness of homogeneous and homogeneizable differential inclusions, Advances in Variable Structure Systems and Sliding Mode Control Theory and Applications. Studies in Systems, Decision and Control, vol.115, pp.39-56, 2018. ,
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, System and Control Letters, vol.62, pp.1159-1167, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877148
Finite-time stability of continuous autonomous systems, SIAM Journal of Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
, Geometric homogeneity with applications to finite-time stability. Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005.
Linear Matrix Inequalities in System and Control Theory, 1994. ,
, Conditions of oscillations and multi-homogeneity. Mathematics of Control, Signals, and Systems, vol.28, pp.1-37, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01223154
Weighted homogeneity for time-delay systems: Finite-time and independent of delay stability, IEEE Transactions on Automatic Control, vol.61, issue.1, pp.210-215, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01145321
Nilpotent and high-order approximations of vector field systems, SIAM Review, vol.33, issue.2, pp.238-264, 1991. ,
H ? control, stabilization, and inputoutput stability of nonlinear systems with homogeneous properties, Automatica, vol.37, issue.7, pp.819-829, 2001. ,
Geometric homogeneity and stabilization, Proc. IFAC Nonlinear Control Symposium, pp.164-169, 1995. ,
On systems of ordinary differential equations with generalized homogeneous right-hand sides. Izvestia vuzov, Mathematica (in Russian), vol.3, issue.22, pp.157-164, 1961. ,
Homogeneous approximations and local observer design. ESAIM: Control, Optimization and Calculus of Variations, vol.19, pp.906-929, 2013. ,
Smooth Lyapunov functions for homogeneous differential inclusions, Proceedings of the 41st SICE Annual Conference, vol.3, pp.1974-1979, 2002. ,
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal of Control and Optimization, vol.43, issue.4, pp.1253-1271, 2004. ,
Semigroups of Linear Operators and Applications to Partial Differential Equations, 1983. ,
Nonlinear feedback design for fixedtime stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
Sliding mode control design using canonical homogeneous norm, Int. J. Robust. Nonlinear Control, vol.29, issue.3, pp.682-701, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01697797
On homogeneous distributed parameter systems, IEEE Transactions on Automatic Control, issue.11, pp.3657-3662, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01318134
Criteria of asymptotic stability of differential inclusions and periodic motions of time-varying nonlinear control systems, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.43, pp.219-229, 1996. ,
Robust output-control for uncertain linear systems: Homogeneous differentiator-based observer approach, Journal of Robust and Nonlinear Control, vol.27, issue.11, pp.1895-1914, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01405383
Homogeneous Lyapunov function for homogeneous continuous vector field, System and Control Letters, vol.19, pp.467-473, 1992. ,
Etude de Quelques Problemes de Stabilization, 1993. ,
Universal stabilization of a class of nonlinear systems with homogeneous vector fields, System and Control Letters, vol.26, pp.177-184, 1995. ,
A 'universal' construction of artstein's theorem on nonlinear stabilization, Systems and Control Letters, vol.13, pp.117-123, 1989. ,
Observers for a class of lipschitz systems with extension to H ? performance analysis, Systems and Control Letters, vol.57, pp.18-27, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00344476
Independent of delay stabilization using implicit lyapunov function method, Automatica, vol.101, pp.103-110, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02418531
A note on delay robustness for homogeneous systems with negative degree, Automatica, vol.79, pp.178-184, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01419131
Robust feedback stabilization of linear MIMO systems using generalized homogenization, IEEE Transactions on Automatic Control, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02614543
On systems of ordinary differential equations with generalized homogenous right-hand sides. Izvestia vuzov, Mathematica (in Russian), vol.1, pp.80-88, 1958. ,
