State and parameter estimation: A nonlinear Luenberger observer approach, IEEE Transactions on Automatic Control, vol.62, issue.2, pp.973-980, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01232747
Highgain observers with updated high-gain and homogeneous correction terms, Automatica, vol.45, issue.2, pp.422-428, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00229705
Robust exact uniformly convergent arbitrary order differentiator, Automatica, vol.49, issue.8, pp.2489-2495, 2013. ,
Robustness of homogeneous and homogeneizable differential inclusions, Advances in Variable Structure Systems and Sliding Mode Control Theory and Applications. Studies in Systems, Decision and Control, vol.115, pp.39-56, 2018. ,
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, System and Control Letters, vol.62, pp.1159-1167, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877148
Finite-time stability of continuous autonomous systems, SIAM Journal of Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
Uniform robust exact differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
Input to state stability and allied system properties. Automation and Remote Control, vol.72, pp.1579-1614, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00639491
Differential equations with discontinuous right-hand sides, 1988. ,
Geometric homogeneity and stabilization, Proc. IFAC Nonlinear Control Symposium, pp.164-169, 1995. ,
Nonlinear observer design using Lyapunov's auxiliary theorem, Systems and Control Letters, vol.34, issue.5, pp.241-247, 1998. ,
Higher-order sliding modes, differentiation and output-feedback control, International Journal of Control, vol.76, pp.924-941, 2003. ,
Finite-time and fixed-time observer design: Implicit lyapunov function approach, Automatica, vol.87, pp.52-60, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01622356
Estimation of solutions of observable nonlinear systems with disturbances, Systems and Control Letters, vol.79, pp.47-58, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01257327
Fixed-time observer with simple gains for uncertain systems, Automatica, vol.81, issue.7, pp.438-446, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01516988
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal of Control and Optimization, vol.43, issue.4, pp.1253-1271, 2004. ,
On dynamic regressor extension and mixing parameter estimators: two Luenberger observers interpretations, Automatica, vol.95, pp.548-551, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01817817
Semigroups of Linear Operators and Applications to Partial Differential Equations, 1983. ,
, , 2008.
, Finite-time observers: Application to secure communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360
Nonlinear feedback design for fixedtime stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
Sliding mode control design using canonical homogeneous norm, Int. J. Robust. Nonlinear Control, vol.29, issue.3, pp.682-701, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01697797
On finite-time stabilization of evolution equations: A homogeneous approach, Proc. of 55th Conference on Decision and Control (CDC), pp.3143-3148, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01371089
On homogeneous distributed parameter systems, IEEE Transactions on Automatic Control, issue.11, pp.3657-3662, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01318134
A nonlinear highgain observer for systems with measurement noise in a feedback control framework, IEEE Transactions on Automatic Control, vol.58, issue.3, pp.569-580, 2013. ,
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.15, issue.3, pp.273-283, 1966. ,
Universal stabilization of a class of nonlinear systems with homogeneous vector fields, System and Control Letters, vol.26, pp.177-184, 1995. ,
On the performance of high-gain observers with gain adaptation under measurement noise, Automatica, vol.47, pp.2165-2176, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00643452
Semi-global finite-time observers for nonlinear systems, Automatica, vol.44, issue.12, pp.3152-3156, 2008. ,
Robust feedback stabilization of linear MIMO systems using generalized homogenization, IEEE Transactions on Automatic Control, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02614543
