A class of robust bounded controllers tracking a nonlinear discrete-time stochastic system: Attractive ellipsoid technique application, Journal of the Franklin Institute, vol.350, issue.5, pp.1008-1029, 2013. ,
Liapunov Functions and Stability in Control Theory, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00139067
Differential neural network identification for homogeneous dynamical systems, IFAC Nonlinear and Control Systems, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02278726
On homogeneity and its application in sliding mode control, Special Issue on 2010-2012 Advances in Variable Structure Systems and Sliding Mode Algorithms, vol.351, pp.1866-1901, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942326
, Geometric homogeneity with applications to finite-time stability. Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005.
Robust trajectory tracking of a delta robot through adaptive active disturbance rejection control, IEEE Transactions on Control Systems Technology, vol.23, issue.4, pp.1387-1398, 2014. ,
Adaptive neural network nonparametric identifier with normalized learning laws, IEEE transactions on neural networks and learning systems, vol.28, pp.1216-1227, 2017. ,
Approximation by superpositions of a sigmoidal function, Mathematics of control, signals and systems, vol.2, issue.4, pp.303-314, 1989. ,
Synthesis of robust controllers and filters, The 22nd IEEE Conference on Decision and Control, pp.109-114, 1983. ,
Adaptive linearization for nonlinear systems using continuous Neural Networks, 7th International Conference on Electrical Engineering Computing Science and Automatic Control, pp.116-121, 2010. ,
On the approximate realization of continuous mappings by neural networks, Neural Networks, vol.2, issue.3, pp.90003-90011, 1989. ,
Nonlinear System Identification Input-Output Modeling Approach, 1999. ,
Tracking control of robot manipulators using Sliding Mode, IEEE Transactions on Power Electronics, issue.2, pp.169-176, 1987. ,
Neural networks: a comprehensive foundation, 1994. ,
Nilpotent approximations of control systems and distributions, SIAM journal on control and optimization, vol.24, issue.4, pp.731-736, 1986. ,
Homogeneous feedback controls for homogeneous systems, Systems & Control Letters, vol.24, issue.1, pp.7-11, 1995. ,
Approximation capabilities of multilayer feedforward networks, Neural networks, vol.4, issue.2, pp.251-257, 1991. ,
Multilayer feedforward networks are universal approximators, Neural networks, vol.2, issue.5, pp.359-366, 1989. ,
Stochastic choice of basis functions in adaptive function approximation and the functional-link net, IEEE Transactions on Neural Networks, vol.6, issue.6, pp.1320-1329, 1995. ,
Identification of nonlinear dynamical systems using multilayered neural networks, Automatica, vol.32, issue.12, pp.1707-1712, 1996. ,
Control of an uncertain three-tank system via on-line parameter indentification and fault detection, IFAC Proceedings Volumes, vol.38, pp.251-256, 2005. ,
Nilpotent Lie algebras of vector fields, J. reine angew. Math, vol.388, pp.1-17, 1988. ,
Geometric homogeneity and stabilization, Nonlinear Control Systems Design, pp.147-152, 1995. ,
Nonlinear systems, vol.3, 2002. ,
Neural network control of robot manipulators and non-linear systems, 1998. ,
System Identification Theory for the User. Prentice Hall Information and System Sciences Series, 1999. ,
Some aspects on Nonlinear System Identification, 14th IFAC Symposium on Identification and System Parameter Estimation, vol.39, pp.553-564, 2006. ,
Nonlinear system identification: from classical approaches to neural networks and fuzzy models, 2013. ,
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
Universal approximation using radial-basis-function networks, Neural Computation, vol.3, issue.2, pp.246-257, 1991. ,
On homogeneous distributed parameter systems, IEEE Transactions on Automatic Control, issue.11, pp.3657-3662, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01318134
Differential neural networks for robust nonlinear control: identification, state estimation and trajectory tracking, World Scientific. Rosier, L, vol.19, pp.467-473, 1992. ,
Sliding mode control in electro-mechanical systems, 2009. ,
A note on delay robustness for homogeneous systems with negative degree, Automatica, vol.79, pp.178-184, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01419131
