Some remarks on a coupling method for the practical computation of homogenized coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2021
We numerically investigate, and improve upon, a computational approach originally introduced in [Cottereau, IJNME 2013] which aims at evaluating the effective coefficient of a medium modelled by a highly oscillatory coefficient. This computational approach is based on a Arlequin type coupling. It combines the original fine-scale description of the medium (modelled by an oscillatory coefficient) with an effective description (modelled by a constant coefficient) and optimizes upon the coefficient of the effective medium to best fit the response of the actual heterogeneous medium using a purely homogeneous medium. We present here a mathematical formalization of the approach along with various improvements of the algorithms, in order to obtain a procedure as efficient as possible. Representative numerical results demonstrate the added value of our approach in comparison to the original approach.
hal-02614896 , version 1 (21-05-2020)
Olga Gorynina, Claude Le Bris, Frédéric Legoll. Some remarks on a coupling method for the practical computation of homogenized coefficients. SIAM Journal on Scientific Computing, 2021, 43 (2), pp.A1273-A1304. ⟨10.1137/20M1339076⟩. ⟨hal-02614896⟩
77 Consultations
0 Téléchargements
