, Anisotropic polygonal remeshing, vol.22, p.3, 2003.
URL : https://hal.archives-ouvertes.fr/inria-00071778
, Recent advances in remeshing of surfaces. STAR AIM@SHAPE, 2005.
Efficient linear system solvers for mesh processing, IMA Conf. on Math. of Surfaces, pp.62-83, 2005. ,
Parameterization of triangle meshes over quadrilateral domains, Symp. on Geometry processing, pp.193-203, 2004. ,
Restricted delaunay triangulations and normal cycle, Proceedings of the Symp. on Computational Geometry, pp.312-321, 2003. ,
Harmonic functions for quadrilateral remeshing of arbitrary manifolds, Computer Aided Design (Special Issue on Geometry Processing), vol.22, pp.392-423, 2005. ,
Discrete differential forms for computational modeling, Discrete Differential Geometry. ACM SIGGRAPH Course Notes, 2005. ,
Mathematical problems in the reconstruction of shapes, Talk at MSRI's Workshop on Computational Algebraic Analysis, 2000. ,
Greedy optimal homotopy and homology generators, SODA (2005), pp.1038-1046 ,
Modeling surfaces of arbitrary topology, Proceedings of ACM SIGGRAPH, pp.359-369, 1995. ,
Global conformal parameterization, Symposium on Geometry Processing, pp.127-137, 2003. ,
Optimal global conformal surface parameterization, IEEE Visualization, pp.267-274, 2004. ,
Globally smooth parameterizations with low distortion, ACM Trans. Graph, vol.22, pp.350-357, 2003. ,
Discrete conformal mappings via circle patterns, ACM Trans. on Graphics, vol.25, issue.2, 2006. ,
Direct anisotropic quad-dominant remeshing, Proceedings of the Pacific Graphics, pp.207-216, 2004. ,
Computing discrete minimal surfaces and their conjugates, Experimental Mathematics, vol.2, issue.1, pp.15-36, 1993. ,
Periodic global parameterization, * 05, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00104853
, , 2005.
Since d ? d = 0, exact forms are always closed. ? Cohomology: The difference between exactness and closedness of 1-forms on surfaces is determined by the topology of the surface. More precisely, two closed forms are said to belong to the same cohomology class if their difference is exact. Cohomology classes of 1-forms form a vector space whose dimension, ACM Trans. on Graphics, vol.23, 2004. ,
Divergence can be written as d * on a 1-form. Note that the Hodge star is metric dependent: if we change the metric, the Hodge star changes accordingly. ? Harmonic Forms: for k > 0, a k-form ? such that ? is closed is called coclosed. A k-form closed and coclosed is called harmonic. It can be shown that there is exactly one harmonic form in each cohomology class. Hence, harmonic 1-forms form a vector space of dimension equal to the first Betti number of the surface. A scalar function f is called harmonic if its Laplacian ? f vanishes ,
