Abstract : In this article, we will introduce two of the new parts of the new multi-part version of the Lexical Markup Framework (LMF) ISO standard, namely Part 3 of the standard (ISO 24613-3), which deals with etymological and diachronic data, and Part 4 (ISO 24613-4), which consists of a TEI serialisation of all of the prior parts of the model. We will demonstrate the use of both standards by describing the LMF encoding of a small number of examples taken from a sample conversion of the reference Portuguese dictionary Grande Dicionário Houaiss da Língua Portuguesa, part of a broader experiment comprising the analysis of different, heterogeneously encoded, Portuguese lexical resources. We present the examples in the Unified Modelling Language (UML) and also in a couple of cases in TEI.
Fahad Khan, Laurent Romary, Ana Salgado, Jack Bowers, Mohamed Khemakhem, et al.. Modelling Etymology in LMF/TEI: The Grande Dicionário Houaiss da Língua Portuguesa Dictionary as a Use Case. LREC 2020 - 12th Language Resources and Evaluation Conference, May 2020, Marseille, France. ⟨hal-02618067⟩
