Differentiator-based velocity observer with sensor bias estimation: an inverted pendulum case study, IFAC Symposium on Nonlinear Control Systems, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02383471
A note on converse Lyapunov-Krasovskii theorems for nonlinear neutral systems in Sobolev spaces, Proc. IFAC NOLCOS, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02418539
On hyper-exponential output-feedback stabilization of a double integrator by using artificial delay, Proc. 17th European Control Conference (ECC), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01755086
Introduction to Time-Delay Systems: Analysis and Control, 2014. ,
Delay-induced stability of vector second-order systems via simple Lyapunov functionals, Automatica, vol.74, pp.288-296, 2016. ,
On input-to-state stability of systems with time-delay: A matrix inequalities approach, Automatica, vol.44, issue.9, pp.2364-2369, 2008. ,
Stabilization by using artificial delays: An LMI approach, Automatica, vol.81, pp.429-437, 2017. ,
, , 2003.
Nonlinear Control, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01248861
Stability of functional differential equations. Academic, 1986. ,
Robust adaptiveoutput-feedback tracking for a class of nonlineartime-delayed plants, IEEE Transactions on AutomaticControl, vol.55, issue.10, pp.2418-2424, 2010. ,
Adaptive output tracking for a class ofnonlinear time delay systems, International Journal ofAdaptive Control and Signal Processing, vol.18, issue.6, pp.489-503, 2004. ,
A Lyapunov-Krasovskii methodology for ISS and iISS of time-delay systems, Systems & Control Letters, vol.55, issue.12, pp.1006-1014, 2006. ,
Lyapunov-Krasovskii characterization of the input-to-state stability for neutral systems in Hale's form. Systems & Control Letters, vol.102, pp.48-56, 2017. ,
Adaptive Control: Stability, Convergence and Robustness, 1989. ,
Connections between Razumikhin-type theorems and the ISS nonlinear small gain theorem, IEEE Trans. Automat. Control, vol.43, issue.7, pp.960-964, 1998. ,
Finite frequency h ? control of singularly perturbed Euler-Lagrange systems: An artificial delay approach, International Journal of Robust and Nonlinear Control, vol.29, issue.2, pp.353-374, 2019. ,
A k-filter-based adaptivecontrol for nonlinear systems with unknown parameters instate and output equations, Automatica, vol.105, pp.186-197, 2019. ,
Robust output feedback controlof polynomial growth nonlinear systems with measurement uncertainty, Int. J. of Robust and Nonlinear Control, vol.29, pp.4562-4576, 2019. ,
