Homogeneous approximation, recursive observer design, and output feedback, SIAM Journal on Control and Optimization, vol.47, issue.4, pp.1814-1850, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00362707
On homogeneity and its application in sliding mode control, Journal of the Franklin Institute, vol.351, issue.4, pp.1866-1901, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942326
, Homogeneity of differential inclusions, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01405148
Finite-time stability of continuous autonomous systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
Geometric homogeneity with applications to finite-time stability. Mathematics of Control, Signals and Systems, vol.17, issue.2, pp.101-127, 2005. ,
Robust finite-time stability of homogeneous systems with respect to multiplicative disturbances, 18th European Control Conference (ECC), pp.668-673, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02084980
On finite-time stability of homogeneous systems with multiplicative bounded function, 18th European Control Conference (ECC), pp.645-649, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02137648
On finite-time stability of weak homogeneous systems, The 6th conference of the Moroccan Society of Applied Mathematics (SM 2 A), 2019. ,
On fixed-time stability of a class of nonlinear time-varying systems, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02614533
Asymptotic stability and smooth Lyapunov functions, Journal of differential Equations, vol.149, issue.1, pp.69-114, 1998. ,
Levant's arbitrary order exact differentiator: a Lyapunov approach, IEEE Transactions on Automatic Control, 2018. ,
Weighted homogeneity for time-delay systems: Finite-time and independent of delay stability, IEEE Transactions on Automatic Control, vol.61, issue.1, pp.210-215, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01145321
Differential equations with discontinuous right-hand sides, 1988. ,
Nilpotent approximations of control systems and distributions, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.731-736, 1986. ,
Geometric homogeneity and stabilization, Nonlinear Control Systems Design, pp.147-152, 1995. ,
Systems of ordinary differential equations with generalized homogeneous right-hand sides, Izvestiya Vysshikh Uchebnykh Zavedenii. Matematika, issue.3, pp.157-164, 1961. ,
Sur les champs de demi-droites et leséquations différentielles du premier ordre. Bulletin de la Société mathématique de France, vol.62, pp.1-38, 1934. ,
Sur les champs continus de demicônes convexes et leurs intégrales, Compositio Mathematica, vol.3, pp.89-127, 1936. ,
Finite time stability and stabilization of a class of continuous systems, Journal of Mathematical Analysis and Applications, vol.323, issue.2, pp.1430-1443, 2006. ,
Sliding mode control design using canonical homogeneous norm, International Journal of Robust and Nonlinear Control, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01697797
On homogeneous finite-time control for linear evolution equation in Hilbert space, IEEE Transactions on Automatic Control, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01695475
On homogeneous distributed parameter systems, IEEE Transactions on Automatic Control, issue.11, pp.3657-3662, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01318134
Stability notions and Lyapunov functions for sliding mode control systems, Journal of the Franklin Institute, vol.351, issue.4, pp.1831-1865, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942319
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, issue.6, pp.467-473, 1992. ,
On homogeneity of discretetime systems: stability and convergence rates, International Journal of Robust and Nonlinear Control, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01996519
Sur leséquations au paratingent, Bull. Sci. Math, vol.60, issue.2, pp.139-160, 1936. ,
On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia Vuzov. mathematica, vol.1, pp.80-88, 1958. ,
Methods of AM Lyapunov and their Application, 1964. ,
