, Stochastic Simulation: Algorithms and Analysis, vol.57, 2007.
Optimization of (s, S) inventory systems with random lead times and a service level constraint, Management Science, vol.44, issue.12, pp.243-256, 1998. ,
Estimating security price derivatives using simulation, Management Science, vol.42, issue.2, pp.269-285, 1996. ,
American option sensitivities estimation via a generalized infinitesimal perturbation analysis approach, Operations Research, vol.62, issue.3, pp.616-632, 2014. ,
Sensitivity estimates for portfolio credit derivatives using Monte Carlo, Finance and Stochastics, vol.12, issue.4, pp.507-540, 2008. ,
Technical note-On the variance of single-run unbiased stochastic derivative estimators, INFORMS Journal on Computing, vol.32, issue.2, pp.390-407, 2020. ,
Modelling dependence with copulas and applications to risk management, Handbook of Heavy Tailed Distributions in Finance, pp.329-384, 2003. ,
Sample path derivatives for (s, S) inventory systems, Operations Research, vol.42, issue.2, pp.351-364, 1994. ,
Stochastic gradient estimation, Handbook of Simulation Optimization, vol.216, pp.105-147, 2015. ,
Conditional Monte Carlo estimation of quantile sensitivities, Management Science, vol.55, issue.12, pp.2019-2027, 2009. ,
Second derivative sample path estimators for the GI/G/m queue, Management Science, vol.39, issue.3, pp.359-383, 1993. ,
Sensitivity analysis for Monte Carlo simulation of option pricing, Probability in the Engineering and Informational Sciences, vol.9, issue.3, pp.417-446, 1995. ,
Conditional Monte Carlo: Gradient Estimation and Optimization Applications, 1997. ,
Efficient design and sensitivity analysis of control charts using Monte Carlo simulation, Management Science, vol.45, issue.3, pp.395-413, 1999. ,
Conditional Monte Carlo gradient estimation in economic design of control limits, vol.18, pp.60-77, 2009. ,
Gradient Estimation via Perturbation Analysis, 1991. ,
Sensitivity estimates from characteristic functions, Operations Research, vol.58, issue.6, pp.1611-1623, 2010. ,
Likelihood ratio gradient estimation: an overview, Proceedings of the 1987, 1987. ,
, Winter Simulation Conference, pp.366-375
Likelihood ratio gradient estimation for stochastic systems, Communications of the ACM, vol.33, issue.10, pp.75-84, 1990. ,
Likelihood ratio gradient estimation for stochastic recursions, Advances in applied probability, vol.27, issue.4, pp.1019-1053, 1995. ,
Computing sensitivities for distortion risk measures. submitted to, INFORMS Journal on Computing, 2020. ,
Smoothed perturbation analysis of discrete event dynamical systems, IEEE Transactions on Automatic Control, vol.32, issue.10, pp.858-866, 1987. ,
, Monte Carlo Methods, 1964.
Optimisation of a single-component maintenance system: a smoothed perturbation analysis approach, European Journal of Operational Research, vol.119, issue.1, pp.181-190, 1999. ,
Gradient estimation for multicomponent maintenance systems with age-replacement policy, Operations Research, vol.58, issue.3, pp.706-718, 2010. ,
Weak differentiability of product measures, Mathematics of Operations Research, vol.35, issue.1, pp.27-51, 2010. ,
Gradient estimation for a class of systems with bulk services (a problem in public transportation), ACM Transactions on Modeling and Computer Simulation, vol.19, issue.3, p.13, 2009. ,
A measure-valued differentiation approach to sensitivity analysis of quantiles, Mathematics of Operations Research, vol.41, issue.1, pp.293-317, 2016. ,
Discrete Event Dynamic Systems and Perturbation Analysis, 1991. ,
Estimating quantile sensitivities, Operations Research, vol.57, issue.1, pp.118-130, 2009. ,
Estimating sensitivities of portfolio credit risk using Monte Carlo, INFORMS Journal on Computing, vol.26, issue.4, pp.848-865, 2014. ,
Simulating sensitivities of conditional value at risk, Management Science, vol.55, issue.2, pp.281-293, 2009. ,
Technical note -On estimating quantile sensitivities via infinitesimal perturbation analysis, Operations Research, vol.63, issue.2, pp.435-441, 2015. ,
A unified view of the IPA, SF, and LR gradient estimation techniques, Management Science, vol.36, issue.11, pp.1364-1383, 1990. ,
Stochastic optimization by simulation: Convergence proofs for the GI/G/1 queue in steady-state, Management Science, vol.40, issue.11, pp.1562-1578, 1994. ,
Monte Carlo and quasi-Monte Carlo density estimation via conditioning, 2019. ,
Applications of generalized likelihood ratio method to distribution sensitivities and steady-state simulation, Journal of Discrete Event Dynamic Systems, vol.28, issue.1, pp.109-125, 2018. ,
Sensitivity analysis of portfolio credit derivatives by conditional Monte Carlo simulation, 2020. ,
On default correlation: a copula approach, Journal of Fixed Income, vol.9, pp.43-54, 2000. ,
Kernel estimation of the Greeks for options with discontinuous payoffs, Operations Research, vol.59, issue.1, pp.96-108, 2011. ,
Families of multivariate distributions, Journal of the American Statistical Association, vol.83, issue.403, pp.834-841, 1988. ,
Monte Carlo gradient estimation in machine learning, 2019. ,
Confidence intervals for quantiles using sectioning when applying variance-reduction techniques, ACM Transactions on Modeling and Computer Simulation, vol.24, issue.4, pp.1-21, 2014. ,
An Introduction to Copulas, vol.139, 2006. ,
On the asymptotic analysis of quantile sensitivity estimation by Monte Carlo simulation, Proceedings of Winter Simulation Conference, pp.2336-2347, 2017. ,
Maximum likelihood estimation by Monte Carlo simulation: Towards data-driven stochastic modeling, Operations Research, 2020. ,
On the regularity conditions and applications for generalized likelihood ratio method, Proceedings of Winter Simulation Conference, pp.919-930, 2016. ,
A new unbiased stochastic derivative estimator for discontinuous sample performances with structural parameters, Operations Research, vol.66, issue.2, pp.487-499, 2018. ,
Stochastic gradient estimation for artificial neural networks. submitted to, INFORMS Journal on Computing, 2020. ,
Derivatives of probability measures-concepts and applications to the optimization of stochastic systems, Discrete Event Systems: Models and Applications, pp.252-274, 1988. ,
Unbiased estimation with square root convergence for SDE models, Operations Research, vol.63, issue.5, pp.1026-1043, 2015. ,
Discrete Event Systems: Sensitivity Analysis and Stochastic Optimization by the Score Function Method, 1993. ,
Approximation Theorems of Mathematical Statistics, 1980. ,
Fonctions de répartitionà n dimensions et leurs marges, vol.8, pp.229-231, 1959. ,
Perturbation analysis gives strongly consistent sensitivity estimates for the M/G/1 queue, Management Science, vol.34, issue.1, pp.39-64, 1988. ,
A new stochastic derivative estimator for discontinuous payoff functions with application to financial derivatives, Operations Research, vol.60, issue.2, pp.447-460, 2012. ,
, Generalized Likelihood Ratio Method for Stochastic Models with Uniform Random Numbers As Inputs
, Jiaqiao Hu Applied Mathematics & Statistics, pp.20742-1815
