Surface Temperature Trend Estimation over 12 Sites in Guinea Using 57 Years of Ground-Based Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Climate Année : 2020
Trend-Run model was performed to estimate the trend in surface temperatures recorded at 12 sites in Guinea from 1960 to 2016 and to examine the contribution of each climate forcing. The coefficient of determination (R 2) calculated varies between 0.60 and 0.90, it provides total information about the simulation capability of the model. The decadal trend values also calculated show an upward trend (between 0.04 °C ± 0.06 °C decade −1 and 0.21 °C ± 0.06 °C decade −1). In addition, forcings' contributions were quantified, and the annual oscillation (AO) contribution is higher for most of the stations, followed by semiannual oscillation (SAO). Among the forcings, the tropical Northern Atlantic (TNA) contribution is greater than that of the sunspot number (SSN), Niño3.4 and Atlantic Niño (AN). Moreover, the Mann-Kendall test revealed a positive significant trend for all stations except at the Macenta site. Additionally, with sequential Mann-Kendall test, trend turning points were found only for the stations of Mamou, Koundara and Macenta at different dates. The temperature anomalies depict warming episodes (1970s, 1980s, 1984 and 1990s). Since then, the temperature is consistently increasing over the country. A significant warming has been shown, which might be further investigated using these models with additional contributing factors.
climate-08-00068.pdf (4.98 Mo) Télécharger le fichier
hal-02666651 , version 1 (31-05-2020)
René Tato Loua, Hassan Bencherif, Nelson Bègue, Nkanyiso Mbatha, Thierry Portafaix, et al.. Surface Temperature Trend Estimation over 12 Sites in Guinea Using 57 Years of Ground-Based Data. Climate , 2020, 8 (6), ⟨10.3390/cli8060068⟩. ⟨hal-02666651⟩
129 Consultations
200 Téléchargements
