Indirect adaptive attenuation of multiple narrow-band disturbances applied to active vibration control, IEEE Transactions on Control Systems Technology, vol.22, issue.2, pp.761-769, 2013. ,
Adaptive sinusoidal disturbance rejection in linear discrete-time systems part ii: Experiments, Journal of dynamic systems, vol.121, issue.4, pp.655-659, 1999. ,
Multiple model adaptive control with safe switching, International journal of adaptive control and signal processing, vol.15, issue.5, pp.445-470, 2001. ,
From youla-kucera to identification, adaptive and nonlinear control, Automatica, vol.34, issue.12, pp.1485-1506, 1998. ,
Multiple model adaptive control using dual youla-kucera factorisation, IFAC Proceedings Volumes, vol.45, pp.63-68, 2012. ,
Closed-loop identification for control of linear parameter varying systems, Asian journal of control, vol.16, issue.1, pp.40-49, 2014. ,
Plug-and-play control modifying control systems online, IEEE Transactions on Control Systems Technology, vol.21, issue.1, pp.79-93, 2011. ,
Plug-and-play control modifying control systems online, IEEE Transactions on Control Systems Technology, vol.21, issue.1, pp.79-93, 2013. ,
Interpolation for gain-scheduled control with guarantees, Automatica, vol.47, issue.1, pp.239-243, 2011. ,
Stable lpv realization of parametric transfer functions and its application to gain-scheduling control design, IEEE transactions on automatic control, vol.55, issue.10, pp.2271-2281, 2010. ,
Active noise control of a duct using robust control theory, IEEE Transactions on Control Systems Technology, vol.8, issue.6, pp.930-938 ,
Pseudo youla-kucera parameterization with control of the waterbed effect for local loop shaping, Automatica, vol.62, pp.177-183, 2015. ,
New repetitive control with improved steady-state performance and accelerated transient, IEEE Transactions on Control Systems Technology, vol.22, issue.2, pp.664-675, 2013. ,
Control of distributed parameter systems subject to convex constraints: Applications to irrigation systems and hypersonic vehicles. In Decision and control, pp.865-870, 2008. ,
The hansen scheme revisited, Decision and control, pp.706-711, 1998. ,
Feedback system design: The fractional representation approach to analysis and synthesis, IEEE transactions on automatic control, vol.25, issue.3, pp.399-412, 1980. ,
Feedback control structures, embedded residual signals, and feedback control schemes with an integrated residual access, IEEE Transactions on Control Systems Technology, vol.18, issue.2, pp.352-367, 2009. ,
Controller tuning freedom under plant identification uncertainty: Double youla beats gap in robust stability, Automatica, vol.39, issue.2, pp.325-333, 2003. ,
Road profile estimation using an adaptive youla-ku ?era parametric observer: Comparison to real profilers, Control engineering practice, vol.61, pp.270-278, 2017. ,
Active noise control. IEEE signal processing magazine, vol.10, pp.12-35, 1993. ,
URL : https://hal.archives-ouvertes.fr/hal-00452718
Closed-loop identification revisited, Automatica, vol.35, issue.7, pp.1215-1241, 1999. ,
Feedback control theory, 1992. ,
URL : https://hal.archives-ouvertes.fr/lirmm-02361068
Parameterizing robust manipulator controllers under approximate inverse dynamics: A double-youla approach, International Journal of Robust and Nonlinear Control, vol.29, issue.15, pp.5137-5163, 2019. ,
A simple architecture for arbitrary interpolation of state feedback, IEEE Control Systems Letters, vol.3, issue.2, pp.469-474, 2019. ,
Asymptotic variance expressions for closed-loop identification, Automatica, vol.37, issue.5, pp.781-786, 2001. ,
Control performance based fault detection for nonlinear systems, In Decision and control (cdc, pp.6358-6363, 2017. ,
Performance-based fault detection and fault-tolerant control for nonlinear systems with ts fuzzy implementation, IEEE transactions on cybernetics, 2019. ,
Closed-loop identification via the fractional representation: Experiment design, American control conference, pp.1422-1427, 1989. ,
Towards the high performance control of uncertain processes via supervision, Proceedings of the 30th conference on information sciences and systems, p.410, 1996. ,
Switching between stabilizing controllers, Automatica, vol.38, issue.11, pp.1905-1917, 2002. ,
For model-based control design, closed-loop identification gives better performance, Automatica, vol.32, issue.12, pp.1659-1673, 1996. ,
A new method for fault tolerant control through q-learning, IFAC-PapersOnLine, vol.51, issue.24, pp.38-45, 2018. ,
Stepwise commissioning of a steam boiler with stability guarantees, Control conference (ecc, pp.49-54, 2016. ,
Efficient adaptive algorithms for arx identification, IEEE Transactions on Signal Processing, vol.39, issue.3, pp.571-582, 1991. ,
Robust estimation for automatic controller tuning with application to active noise control, Model-based control, pp.107-124, 2009. ,
Stability of discrete linear feedback systems, IFAC Proceedings Volumes, vol.8, pp.573-578, 1975. ,
On the use of youla-kucera parametrization in adaptive active noise and vibration control-a review, International journal of control, pp.1-25, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01920419
Why one should use youla-kucera parametrization in adaptive feedforward noise attenuation, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02190768
, JARAP, vol.21, p.58, 2020.
Adaptive narrow band disturbance rejection applied to an active suspension an internal model principle approach, Automatica, vol.41, issue.4, pp.563-574, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00384489
Recursive algorithms for identification in closed loop: A unified approach and evaluation, Automatica, vol.33, issue.8, pp.1499-1523, 1997. ,
Adaptive control: Algorithms, analysis and applications, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01060312
Active noise control: Adaptive vs. robust approach, Control and automation, pp.799-804, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01599715
Beyond the delay barrier in adaptive feedforward active noise control using youla-ku ?era parametrization, Journal of sound and vibration, vol.455, pp.339-358, 2019. ,
Benchmark on adaptive regulation rejection of unknown/time-varying multiple narrow band disturbances, European Journal of control, vol.19, issue.4, pp.237-252, 2013. ,
Combined pole placement/sensitivity function shaping method using convex optimization criteria, Automatica, vol.35, issue.6, pp.1111-1120, 1999. ,
Performance-based fault detection and fault-tolerant control for automatic control systems, Automatica, vol.99, pp.308-316, 2019. ,
Switching in systems and control, 2003. ,
Active noise cancellation in headphones by digital robust feedback control, pp.1843-1847, 2016. ,
Identification of nonlinear plants using left coprime fractional based representations, Control conference (ecc), pp.772-777, 1997. ,
Identification of nonlinear plants under linear control using youla-kucera parametrizations, Decision and control, pp.1094-1098, 1996. ,
Control of disturbed lpv systems in a lmi setting, IFAC Proceedings Volumes, vol.44, pp.4149-4154, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00633256
, Youla-kucera based lateral controller for autonomous vehicle. itsc 2018-21st ieee international conference on intelligent transportation systems, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01906268
Improving playability of blu-ray disc drives by using adaptive suppression of repetitive disturbances, Automatica, vol.48, issue.4, pp.638-644, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01250319
Data driven design of tonal noise feedback cancellers, IFAC-PapersOnLine, vol.50, issue.1, pp.916-921, 2017. ,
Local controller synthesis for plug and play processes by decomposition, 2009 ieee international conference on control and automation, pp.2223-2228, 2009. ,
Loop reconvery via hinf/h2 sensitivity recovery, International Journal Control, vol.49, issue.4, pp.1249-1271, 1989. ,
On improving control-loop robustness of model-matching controllers, Systems & control letters, vol.7, issue.2, pp.83-87, 1986. ,
Mixing v2v-and non-v2v-equipped vehicles in car following. Transportation research part C: emerging technologies, vol.108, pp.167-181, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02392487
Using plug&play control for stable acc-cacc system transitions, Intelligent vehicles symposium (iv, pp.704-709, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01304542
Youla-kucera based online closed-loop identification for longitudinal vehicle dynamics, 2017 21st international conference on system theory, control and computing (icstcc), pp.88-93, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01591705
Multi-model adaptive control for cacc applications, IEEE Transactions on Intelligent Transportation Systems, vol.99, pp.1-11, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02470639
Analytical design of linear feedback controls, 1957. ,
Dual youla parameterisation, IEE Proceedings-Control Theory and Applications, vol.150, issue.5, pp.93-97, 2003. ,
Parameterisation of extended systems, IEE Proceedings-Control Theory and Applications, vol.153, issue.2, pp.221-227, 2006. ,
A setup for active fault diagnosis, IEEE transactions on automatic control, vol.51, issue.9, pp.1572-1578, 2006. ,
A model-based approach to fault-tolerant control, International Journal of Applied Mathematics and Computer Science, vol.22, issue.1, pp.67-86, 2012. ,
Fault tolerant control for uncertain systems with parametric faults, IFAC Proceedings Volumes, vol.39, pp.80-84, 2006. ,
Controller architectures for switching, pp.1098-1103, 2009. ,
Reliable control using the primary and dual youla parameterizations, Decision and control, pp.4353-4358, 2002. ,
An architecture for fault tolerant controllers, International journal of control, vol.78, issue.14, pp.1091-1110, 2005. ,
Passive fault tolerant control of a double inverted pendulum a case study, Control engineering practice, vol.13, issue.8, pp.1047-1059, 2005. ,
Switching between multivariable controllers, Optimal control applications and methods, vol.25, issue.2, pp.51-66, 2004. ,
Gain scheduling via linear fractional transformations, Systems & control letters, vol.22, issue.2, pp.79-92, 1994. ,
Applicable Algebra in Engineering, vol.9, pp.91-116, 1998. ,
Stable controller interpolation and controller switching for lpv systems, Journal of dynamic systems, vol.132, issue.1, p.11007, 2010. ,
Research on gain scheduling, Automatica, vol.20, issue.0, pp.1401-1425 ,
Lpv identification of a turbocharged diesel engine, Applied Numerical Mathematics, vol.58, issue.10, pp.1553-1571, 2008. ,
Identification of linear parameter varying systems using an iterative deterministic-stochastic subspace approach, vol.873, pp.4-867, 2007. ,
An open-loop solution to the approximate closed-loop identification problem, IFAC Proceedings Volumes, vol.24, pp.761-766, 1991. ,
Closed loop identification using a modified hansen scheme, Journal of physics: Conference series, p.12009, 2015. ,
Closed loop identification of a piezoelectrically controlled radial gas bearing: Theory and experiment, Proceedings of the Institution of Mechanical Engineers, Part I: Journal of Systems and Control Engineering, vol.232, issue.7, pp.926-936, 2018. ,
An observer parameterization approach to active fault diagnosis with applications to a drag racing vehicle, IFAC Proceedings Volumes, vol.42, pp.591-596, 2009. ,
Plug & play control: Control technology towards new challenges, European Journal of Control, vol.15, issue.3-4, pp.311-330, 2009. ,
Starting up unstable multivariable controllers safely, Proceedings of the 36th ieee conference on decision, pp.1437-1438, 1997. ,
An lmi approach to control-oriented identification and model (in) validation of lpv systems, IEEE transactions on automatic control, vol.48, issue.9, pp.1619-1624, 2003. ,
Youla-kucera parameterization-based optimally closed-loop control for tip-tilt compensation, IEEE sensors journal, vol.18, issue.15, pp.6154-6160, 2018. ,
Enhancement of fixed controllers via adaptive-q disturbance estimate feedback, Automatica, vol.27, issue.1, pp.39-53, 1991. ,
High performance control, 1997. ,
Enhancing robust controllers with adaptive techniques, 1989. ,
Design of al/sup 1/-optimal regulator: The limits of performance approach, IEEE transactions on automatic control, vol.40, issue.12, pp.2114-2119, 1995. ,
Dealing with periodic disturbances in controls of mechanical systems, Annual reviews in control, vol.32, issue.2, pp.193-199, 2008. ,
, Controller reconfiguration through terminal connections based on closed-loop system identification1. IFAC Proceedings Volumes, vol.42, pp.25-30, 2009.
Safe lpv controller switching. In Decision and control and european control conference (cdc-ecc), pp.3428-3433, 2011. ,
Stable controller reconfiguration through terminal connections. a practical example, Control and automation, 2009. icca 2009. ieee international conference on, pp.2037-2042, 2009. ,
Lpv identification of a heat distribution system, Ieee international conference in control applications, pp.2178-2183, 2010. ,
Stable controller reconfiguration through terminal connections, IFAC Proceedings Volumes, vol.41, pp.331-335, 2008. ,
Optimal operation of fed-batch fermentations via adaptive control of overflow metabolite, Control engineering practice, vol.11, issue.6, pp.665-674, 2003. ,
Youla-kucera adaptive feedback disturbance rejection in the presence of plant uncertainties, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02305421
Control systems synthesis: A factorization approach, vol.8, 1985. ,
Performance Issues in Adaptive Control, 1991. ,
Adaptive disturbance rejection. In Decision and control, proceedings of the 30th ieee conference on, vol.45, pp.1167-1172, 1991. ,
Youla parameterized adaptive vibration suppression with adaptive notch filter for unknown multiple narrow band disturbances, Journal of Vibration and Control, p.1077546318794539, 2018. ,
Design of switched linear control systems based on youla parameterization with average dwell time, International journal of systems science, vol.50, issue.1, pp.203-215, 2019. ,
Design of lpv control systems based on youla parameterisation, IEE Proceedings-Control Theory and Applications, vol.151, issue.4, pp.465-472, 2004. ,
Stabilization of nested systems with uncertain subsystem communication channels, 42nd ieee international conference on decision and control, pp.2853-2858, 2003. ,
Real-time implementation of fault-tolerant control systems with performance optimization, IEEE Transactions on Industrial Electronics, vol.61, issue.5, pp.2402-2411, 2013. ,
Modern wiener-hopf design of optimal ARTICLE IN PRESS JID: JARAP [m5G, vol.21, p.58, 1976. ,
, controllers part i: The single-input-output case, IEEE transactions on automatic control, vol.21, issue.1, pp.3-13
Modern wiener-hopf design of optimal controllers-part ii: The multivariable case, IEEE transactions on automatic control, vol.21, issue.3, pp.319-338, 1976. ,
Active noise control in a duct using output feedback robust control techniques, Proceedings of the 2010 american control conference, pp.3506-3511, 2010. ,
The l2 (l2) bumpless transfer problem for linear plants: Its definition and solution, Automatica, issue.7, pp.1273-1280, 2005. ,
Recursive filter estimation for feedforward noise cancellation with acoustic coupling, Journal of sound and vibration, vol.291, issue.3-5, pp.1061-1079, 2006. ,
Bibliographical review on reconfigurable fault-tolerant control systems, Annual reviews in control, vol.32, issue.2, pp.229-252, 2008. ,
A new controller architecture for high performance, robust, and fault-tolerant control, IEEE transactions on automatic control, vol.46, issue.10, pp.1613-1618, 2001. ,
