RFC 6550: On Minimizing the Control Plane Traffic of RPL-based Industrial Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The IPv6 Routing Protocol for Low-Power and Lossy Networks (RPL) is the de facto routing protocol for Low Power and Lossy Networks (LLNs). It is a proactive and link-layer agnostic routing protocol standardized as RFC 6550 by the Internet Engineering Task Force (IETF). Based on the distance-vector technique, RPL builds a Destination Oriented Directed Acyclic Graph (DODAG) topology. To establish and maintain the routes, RPL uses DODAG Information Object (DIO) control packets, that are transmitted in broadcast, for RPL nodes to propagate the DODAG related information, while its transmission frequency depends on Trickle timer algorithm, i.e., the less stable the network the more DIOs are transmitted. Thus, when a new node intends to join the RPL DODAG, it listens for a DIO message from nearby nodes, which may take a very long time if the network is in a stable state. Therefore, RFC 6550 is equipped with the DODAG Informational Solicitation (DIS) message to solicit DIOs from nearby RPL nodes, similar to the Router Solicitation in IPv6 Neighbor Discovery. However, the solicitation procedure is not the most efficient one, since it resets the Trickle timers in the nodes that receive the DIS message and, thus, they transmit an unnecessarily large number of DIOs that congest the network and consume energy in the nodes. In this paper, we propose to augment RFC 6550, the RPL routing protocol, with additional DIS flags and options that allow a RPL node to better control how the nearby RPL nodes will respond to its solicitation for DIOs. Our performance evaluation in Contiki-NG & COOJA demonstrates that we can reduce the control packets in the network by up to 45.5%.
DIS_Modification_Flag_Test_Results.pdf (1.99 Mo) Télécharger le fichier
hal-02749045 , version 1 (03-06-2020)
Dimitrios Sourailidis, Remous-Aris Koutsiamanis, Georgios Papadopoulos, Dominique Barthel, Nicolas Montavont. RFC 6550: On Minimizing the Control Plane Traffic of RPL-based Industrial Networks. WoWMoM 2020 - IEEE 21st International Symposium on "A World of Wireless, Mobile and Multimedia Networks", Aug 2020, Cork, Ireland. pp.439-444, ⟨10.1109/WoWMoM49955.2020.00080⟩. ⟨hal-02749045⟩
143 Consultations
298 Téléchargements
