Using A Quadrotor As Wind Sensor: Time-Varying Parameter Estimation Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2020
The objective of this paper is to develop an algorithm for the estimation of time-varying wind parameters by taking into account a detailed quadrotor model. The design objectives include the time convergence optimization, robustness to measurement noises, and a guaranteed convergence of the estimates to the true values under mild applicability conditions. It is supposed that the estimation algorithm can use IMU (accelerometers, gyroscopes) sensors augmented with an earth reference tracking system and rotor rotational velocity sensors. To this end, three time-varying parameter estimation algorithms are introduced, compared and finally merged to estimate the varying wind velocity in on-board quadrotor systems. Final numerical experiments , using a nonlinear quadrotor simulator, are used to validate the proposed approaches.
_manuscript_rev2_GP.pdf (632.87 Ko) Télécharger le fichier
hal-02784701 , version 1 (04-06-2020)
Gabriele Perozzi, Denis Efimov, Jean-Marc Biannic, Laurent Planckaert. Using A Quadrotor As Wind Sensor: Time-Varying Parameter Estimation Algorithms. International Journal of Control, In press, 95 (1), pp.126-137. ⟨10.1080/00207179.2020.1780324⟩. ⟨hal-02784701⟩
83 Consultations
389 Téléchargements
