Computing the action of the matrix exponential, with an application to exponential integrators, SIAM J. Sc. Comp, vol.33, issue.2, pp.488-511, 2011. ,
Domain adaptation problems: A dasvm classification technique and a circular validation strategy, IEEE Trans. Pattern Anal. Mach. Intell, vol.32, issue.5, pp.770-787, 2010. ,
The heat kernel as the pagerank of a graph, Proceedings of the National Academy of Sciences, vol.104, issue.50, pp.19735-19740, 2007. ,
Domain adaptation with regularized optimal transport, Machine Learning and Knowledge Discovery in Databases, pp.274-289, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01018698
Optimal transport for domain adaptation, IEEE Trans. Pattern Anal. Mach. Intell, vol.39, issue.9, pp.1853-1865, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01377220
Pygsp: Graph signal processing in python, 2017. ,
Contextual stochastic block models, NeurIPS 2018, pp.8590-8602, 2018. ,
Pot python optimal transport library, 2017. ,
Graph diffusion distance: A difference measure for weighted graphs based on the graph laplacian exponential kernel, GlobalSIP, pp.419-422, 2013. ,
Stochastic blockmodels: First steps, Social networks, vol.5, issue.2, pp.109-137, 1983. ,
On the translocation of masses, Doklady of the Academy of Sciences of the USSR, vol.37, pp.199-201, 1942. ,
A survey on graph kernels, Applied Network Science, vol.5, issue.1, p.6, 2020. ,
GOT: an optimal transport framework for graph comparison, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02150008
Wassersteinbased graph alignment, 2020. ,
Mémoire sur la théorie des déblais et des remblais. Histoire de l'Académie royale des sciences de, 1781. ,
Gromov-wasserstein distances and the metric approach to object matching, Found. Comput. Math, vol.11, issue.4, pp.417-487, 2011. ,
Graph signal processing: Overview, challenges, and applications, Proceedings of the IEEE, vol.106, issue.5, pp.808-828, 2018. ,
, Computational Optimal Transport. arXiv, 2018.
Gromov-wasserstein averaging of kernel and distance matrices, Int. Conf. on Machine Learning, vol.48, pp.2664-2672, 2016. ,
, Advances in Domain Adaptation Theory, p.187, 2019.
URL : https://hal.archives-ouvertes.fr/hal-02286281
Learning heat diffusion graphs, IEEE Trans. on Sig. and Info. Proc. over Networks, vol.3, issue.3, pp.484-499, 2017. ,
, Compressive Spectral Clustering. In: 33rd Int. Conf. on Machine Learning, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01320214
Netlsd: Hearing the shape of a graph, ACM Int. Conf. on Knowledge Discovery & Data Mining, pp.2347-2356, 2018. ,
Optimal transport for structured data with application on graphs, Int. Conf. on Machine Learning, vol.97, pp.6275-6284, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02174322
