Strong approximation of some particular one-dimensional diffusions
We develop a new technique for the path approximation of one-dimensional stochastic processes. Our results apply to the Brownian motion and to some families of stochastic differential equations whose distributions could be represented as a function of a time-changed Brownian motion (usually known as L and G-classes). We are interested in the epsilon-strong approximation. We propose an explicit and easy-to-implement procedure that jointly constructs, the sequences of exit times and corresponding exit positions of some well-chosen domains. In our main results, we prove the convergence of our scheme and how to control the number of steps, which depends on the covering of a fixed time interval by intervals of random sizes. The underlying idea of our analysis is to combine results on Brownian exit times from time-depending domains (one-dimensional heat balls) and classical renewal theory. Numerical examples and issues are also developed in order to complete the theoretical results.
Mots clés
Brownian motion
linear diffusion
path simulation
Strong approximation path simulation Brownian motion linear diffusion. 2010 AMS subject classifications: primary 65C05
secondary 60J60 60J65 60G17
secondary 60J60
60J65
60G17
Probabilités [math.PR]
HAL2-DH.pdf (462.91 Ko)
Télécharger le fichier
Ex1-courbe-eps-converted-to.pdf (14.7 Ko)
