Where is that Feature? Designing for Cross-Device Software Learnability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jessalyn Alvina
  • Fonction : Auteur
  • PersonId : 1053341
Andrea Bunt
  • Fonction : Auteur
  • PersonId : 1072701
Sylvain Malacria
Joanna Mcgrenere
  • Fonction : Auteur
  • PersonId : 1005960
People increasingly access cross-device applications from their smartphones while on the go. Yet, they do not fully use the mobile versions for complex tasks, preferring the desktop version of the same application. We conducted a survey (N=77) to identify challenges when switching back and forth between devices. We discovered significant cross-device learnability issues, including that users often find exploring the mobile version frustrating, which leads to prematurely giving up on using the mobile version. Based on the findings, we created four design concepts as video prototypes to explore how to support cross-device learnability. The concepts vary in four key dimensions: the device involved, automation, temporality, and learning approach. Interviews (N=20) probing the design concepts identified individual differences affecting cross-device learning preferences, and that users are more motivated to use cross-device applications when offered the right cross-device learnability support. We conclude with future design directions for supporting seamless cross-device learnability.
CHI2020_CrossDeviceLearnability.pdf (3.96 Mo) Télécharger le fichier
hal-02824512 , version 1 (06-06-2020)
Paternité
Jessalyn Alvina, Andrea Bunt, Parmit K Chilana, Sylvain Malacria, Joanna Mcgrenere. Where is that Feature? Designing for Cross-Device Software Learnability. Proceedings of the ACM Conference on Designing Interactive Systems (DIS 2020), Jul 2020, Eindhoven, Netherlands. ⟨10.1145/3357236.3395506⟩. ⟨hal-02824512⟩
94 Consultations
335 Téléchargements
