Workflow management for real-time analysis of lightsource experiments, Proc. of WORKS'14, pp.31-40, 2014. ,
, CMS data processing workflows during an extended cosmic ray run, Journal of Instrumentation, vol.5, issue.03, pp.3-006, 2010.
Pilot-streaming: A stream processing framework for high-performance computing, 2018. ,
Reliability-aware dynamic energy management in dependable embedded real-time systems, ACM Trans. on Embedded Computing Systems, vol.10, p.27, 2011. ,
The effects of energy management on reliability in real-time embedded systems, Proc. of ICCAD'04, pp.35-40, 2004. ,
Support for HTCondor high-throughput computing workflows in the REANA reusable analysis platform, CERN, 2019. ,
Language and compiler support for stream programs, MIT, 2009. ,
Optimization of duplication-based schedules on networkon-chip based multi-processor system-on-chips, IEEE Transactions on Parallel and Distributed Systems, vol.28, issue.3, pp.826-837, 2017. ,
Performance estimation of streaming applications for hierarchical mpsocs, Proceedings of the 2016 Workshop on Rapid Simulation and Performance Evaluation: Methods and Tools, ser. RAPIDO '16, vol.3, pp.1-3, 2016. ,
Mapping streaming applications on commodity multi-cpu and gpu on-chip processors, IEEE Transactions on Parallel and Distributed Systems, vol.27, issue.4, pp.1099-1115, 2016. ,
DVFS-enabled power-performance trade-off in MPSoC SW application mapping, SAMOS'17, pp.196-202, 2017. ,
On reliability management of energy-aware real-time systems through task replication, IEEE TPDS, vol.28, issue.3, pp.813-825, 2017. ,
Thermal-aware task scheduling for energy minimization in heterogeneous real-time mpsoc systems, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.35, issue.8, pp.1269-1282, 2016. ,
Cola: Optimizing stream processing applications via graph partitioning, pp.308-327, 2009. ,
A budget constrained scheduling of workflow applications on utility grids using genetic algorithms, 2006 Workshop on Workflows in Support of Large-Scale Science, pp.1-10, 2006. ,
Software pipelinebased partitioning method with trade-off between workload balance and communication optimization, ETRI Journal, vol.37, issue.3, pp.562-572, 2015. ,
Scheduling of scientific workflows in the askalon grid environment, SIGMOD Rec, vol.34, issue.3, pp.56-62, 2005. ,
A communication model and partitioning algorithm for streaming applications for an embedded mpsoc, 2014 International Symposium on System-on-Chip (SoC), pp.1-6, 2014. ,
Traleika glacier: A hardware-software co-designed approach to exascale computing, Parallel Computing, vol.64, pp.33-49, 2017. ,
Mapping pipeline skeletons onto heterogeneous platforms, J. Parallel and Distributed Computing, vol.68, issue.6, pp.790-808, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00122884
Tradeoff exploration between reliability, power consumption, and execution time for embedded systems, International Journal on Software Tools for Technology Transfer, vol.15, pp.229-245, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00923926
Approximation algorithms for energy, reliability, and makespan optimization problems, Parallel Process. Lett, vol.26, issue.1, pp.1-23, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00742754
Minimizing energy consumption with reliability goal on heterogeneous embedded systems, J. of Parallel and Distributed Computing, vol.127, pp.44-57, 2019. ,
Computers and Intractability, A Guide to the Theory of NP-Completeness, 1979. ,
Energy Efficiency Features of the Intel Skylake-SP Processor and Their Impact on Performance, CoRR, 2019. ,
