Call graph prefetching for database applications, HPCA, 2001. ,
Two level bulk preload branch prediction, HPCA, 2013. ,
Phantom-BTB: a virtualized branch target buffer design, ASPLOS, 2009. ,
Instruction prefetching using branch prediction information, ICCD, 1997. ,
A primer on hardware prefetching, 2014. ,
Proactive instruction fetch, MICRO, 2011. ,
Temporal instruction fetch streaming, 2008. ,
High performance cache replacement using re-reference interval prediction (RRIP), ISCA, 2010. ,
Confluence: unified instruction supply for scale-out servers, 2015. ,
RDIP: return-addressstack directed instruction prefetching, 2013. ,
Blasting through the front-end bottleneck with Shotgun, ASPLOS, 2018. ,
Boomerang: a metadata-free architecture for control flow delivery, HPCA, 2017. ,
Wrong-path instruction prefetching, MICRO, 1996. ,
Fetch directed instruction prefetching, MICRO, 1999. ,
Prefetching in supercomputer instruction cache, Supercomputing, 1992. ,
Effective instruction prefetching in chip multiprocessors for modern commercial applications, HPCA, 2005. ,
Branch history guided instruction prefetching, HPCA, 2001. ,
