, Dynamic Meteorology: Data Assimilation Methods, Applied 632 Mathematical Sciences, vol.36, 1981.
Efficient big data assimilation through sparse representation: 634 A 3d benchmark case study in petroleum engineering, PLoS One, vol.13, p.198586, 2018. ,
, Data Assimilation and Control: Theory and Applications, p.637
, Life Sciences (Frontiers Media, 2019.
, Neural Control Engineering, 2011.
, , pp.2053-2563, 2015.
, Data Assimilation: Methods, Algorithms, and Applications, vol.642, 2016.
Efficient data assimilation for spatiotemporal chaos: A local 644 ensemble transform Kalman filter, Physica D, vol.230, pp.112-126, 2007. ,
Kilometre-scale ensemble 646 data assimilation for the cosmo model (kenda). Q, J. R. Meteorol. Soc, vol.142, pp.1453-1472, 2016. ,
A concept for the assimilation of satellite cloud information 649 in an ensemble Kalman filter: single-observation experiments, Q. J. R. Meteorol. Soc, vol.141, pp.893-908, 2015. ,
Assimilating satellite radiances with a local ensemble transform Kalman filter 652 (letkf) applied to the jma global model (gsm), SOLA, vol.3, pp.37-40, 2007. ,
A review of the use of geostationary 654 satellite observations in regional-scale models for short-term cloud forecasting, Meteorologische, vol.655, pp.277-298, 2018. ,
Assimilating non-local observations with a local ensemble 657 ,
, Tellus A, vol.59, pp.719-730, 2007.
Assimilation of SEVIRI 659 water vapour channels with an ensemble Kalman filter on the convective scale, Front. Earth Sci, vol.8, p.70, 2019. ,
Estimation of high-dimensional prior and posterior covariance matrices in 662 ,
, Kalman filter variants. J. Multivar. Ana, vol.98, pp.227-255, 2007.
An ensemble adjustment Kalman filter for data assimiliation, Mon. Wea. Rev, vol.129, pp.2884-2903, 2001. ,
Distance-dependent filtering of background error covariance 666 estimates in an ensemble Kalman filter, Mon. Wea. Rev, vol.129, pp.1520-0493, 2001. ,
Nonlinear stability and ergodicity of ensemble based Kalman filters ,
, Nonlinearity, vol.29, pp.657-691, 2016.
Nonlinear stability of ensemble Kalman filters with adaptive covariance 671 inflation, Commun. Math. Sci, vol.14, pp.1283-1313, 2016. ,
A mechanism for catastrophic filter divergence in data assimilation for sparse 673 observation networks, Nonlin. Processes Geophys, vol.20, pp.705-712, 2013. ,
Concrete ensemble Kalman filters with rigorous catastrophic filter 675 divergence, Proc. Natl. Acad. Sci. USA, vol.112, pp.10589-10594, 2015. ,
Catastrophic filter divergence in filtering nonlinear dissipative systems, Comm ,
, Math. Sci, vol.8, pp.27-43, 2008.
All-sky satellite data assimilation of microwave temperature sounding channels 679 at the met office, Quart. J. Roy. Meteor. Soc, vol.145, pp.867-883, 2019. ,
Optimal sites for supplementary weather observations: Simulations 681 with a small model, J. Atmos. Sci, vol.555, pp.399-414, 1998. ,
Gain form of the Ensemble Transform Kalman Filter and its relevance 684 to satellite data assimilation with model space ensemble covariance localization, Mon. Wea. Rev, vol.145, pp.4575-4592, 2017. ,
Estimating correlated observation error statistics 687 using an ensemble transform Kalman filter, Tellus A, vol.66, p.23294, 2014. ,
Review of the ensemble Kalman filter for atmospheric data assimilation ,
, Wea. Rev, vol.144, pp.4489-4532, 2016.
Optimal localization for ensemble Kalman filter systems, J. Met ,
, Soc. Japan, vol.92, pp.585-597, 2014.
Balance and ensemble Kalman filter localization 693 techniques, Mon. Wea. Rev, vol.139, pp.511-522, 2011. ,
Construction of correlation functions in two and three dimensions ,
, Soc, vol.125, pp.723-757, 1999.
Transformed and generalized localization for ensemble methods in data 697 assimilation, Math. Meth. Appl. Sci, vol.39, pp.619-634, 2016. ,
Ensemble covariances adaptively localized with eco-rap. part 2: a strategy for 699 the atmosphere, Tellus, vol.61, pp.97-111, 2009. ,
A new data assimilation scheme: the space-expanded ensemble 701 localization Kalman filter, Adv. Meteorol, vol.2013, p.410812, 2013. ,
Local Ensemble Transform Kalman Filtering with an AGCM at a T159/L48 703 resolution, Mon. Wea. Rev, vol.135, pp.3841-3861, 2007. ,
On the efficiency of covariance localisation of the ensemble Kalman filter using 705 augmented ensembles, Front. Appl. Math. Stat, vol.5, p.3, 2019. ,
Model space localization is not always better than observation space 707 localization for assimilation of satellite radiances, Mon. Wea. Rev, vol.143, 2015. ,
Vertical covariance localization for satellite radiances in 710 ensemble Kalman filters, Mon. Wea. Rev, vol.138, pp.282-290, 2010. ,
Atmospheric data 712 assimilation with an ensemble Kalman filter: Results with real observations, Mon. Wea. Rev, vol.133, pp.604-620, 2005. ,
Accuracy and stability of numerical algorithms (SIAM), 2002. ,
A monte carlo implementation of the nonlinear filtering problem to 716 produce ensemble assimilations and forecasts, Mon. Wea. Rev, vol.127, pp.1520-0493, 1999. ,
Covariance inflation in the ensemble Kalman filter: A residual nudging perspective 719 and some implications, Mon. Weath. Rev, vol.141, pp.3360-3368, 2013. ,
What constrains spread growth in forecasts initialized from ensemble 721 Kalman filters ? Mon, Wea. Rev, vol.139, pp.117-131, 2011. ,
An adaptive ensemble Kalman filter, Mon. Weath. Rev, vol.128, pp.416-433, 2000. ,
Kalman filtering: Theory and practice useing MATLAB, 2001. ,
On instabilities in data assimilation algorithms, Mathematics, vol.8, 2012. ,
Data assimilation: making sense of earth observation. Front, Environ. Sci, vol.2, p.16, 2014. ,
Performance analysis of local ensemble Kalman filter, J. Nonlinear. Sci, vol.28, pp.731-1397, 2018. ,
On the selection of localization radius in ensemble filtering for multiscale 733 quasigeostrophic dynamics, Mon. Wea. Rev, vol.146, pp.543-560, 2018. ,
A multi-scale localization approach to an ensemble Kalman filter, SOLA, vol.9, pp.170-173, 2013. ,
Information-based data selection for ensemble data assimilation, Quart. J. Roy. Meteor ,
, Soc, vol.139, pp.2033-2054, 2013.
On the choice of an optimal localization radius 739 in Ensemble Kalman Filter methods, Mon. Wea. Rev, vol.142, pp.2165-2175, 2014. ,
Commentary: On the efficiency of covariance localisation of the 742 ensemble Kalman filter using augmented ensembles by alban farchi and marc bocquet, Front. Appl ,
Improving assimilation of radiance observations by implementing model 745 space localization in an ensemble Kalman filter, J. Adv. Model. Earth Syst, vol.10, pp.3221-3232, 2018. ,
The role of model dynamics in ensemble Kalman 748 filter performance for chaotic systems, Tellus A, vol.63, pp.958-977, 2011. ,
A probabilistic approach to adaptive covariance localization for serial ensemble 750 square root filters, Mon. Wea. Rev, vol.142, pp.4499-4518, 2014. ,
Towards a theory of optimal localisation, Tellus A, vol.67, p.25257, 2015. ,
Preventing catastrophic filter divergence using adaptive additive inflation for 753 baroclinic turbulence, Mon. Wea. Rev, vol.145, pp.669-682, 2017. ,
The gaussian approach to adaptive covariance inflation and its implementation with 755 the local ensemble transform Kalman filter, Mon. Wea. Rev, vol.139, pp.1519-1535, 2011. ,
