Browser Fingerprinting: A Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on the Web Année : 2020
With this article, we survey the research performed in the domain of browser fingerprinting, while providing an accessible entry point to newcomers in the field. We explain how this technique works and where it stems from. We analyze the related work in detail to understand the composition of modern fingerprints and see how this technique is currently used online. We systematize existing defense solutions into different categories and detail the current challenges yet to overcome.
browserfp-survey.pdf (877.04 Ko) Télécharger le fichier
hal-02864872 , version 1 (11-08-2020)
Pierre Laperdrix, Nataliia Bielova, Benoit Baudry, Gildas Avoine. Browser Fingerprinting: A Survey. ACM Transactions on the Web, 2020, 14 (2), pp.1-33. ⟨10.1145/3386040⟩. ⟨hal-02864872⟩
285 Consultations
888 Téléchargements
