Efficient aerodynamic design using the discrete adjoint method in SU2, 17th AIAA/ISSMO multidisciplinary analysis and optimization conference, p.3518, 2016. ,
, Comparison of various CFD codes for LES simulations of turbomachinery: from inviscid vortex convection to multi-stage compressor, vol.2, 2018.
Optimal multistage algorithm for adjoint computation, SIAM Journal on Scientific Computing, vol.38, issue.3, pp.232-255, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01147155
Low-dissipation and low-dispersion fourth-order Runge-Kutta algorithm, Computers & Fluids, vol.35, issue.10, pp.1459-1463, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-02342209
Least-squares shadowing sensitivity analysis of chaotic flow around a two-dimensional airfoil, AIAA Journal, vol.56, issue.2, pp.658-672, 2018. ,
Jaguar: a new CFD code dedicated to massively parallel high-order LES computations on complex geometry, The 50th 3AF International Conference on Applied Aerodynamics (AERO 2015), 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01965640
Checkpointing schemes for adjoint codes: application to the meteorological model Meso-NH, SIAM Journal on Scientific Computing, vol.22, issue.6, pp.2135-2151, 2001. ,
Xfoil: An analysis and design system for low reynolds number airfoils, Low Reynolds Number Aerodynamics, pp.1-12, 1989. ,
Evaluating derivatives: principles and techniques of algorithmic differentiation, vol.105, 2008. ,
The Tapenade automatic differentiation tool: principles, model, and specification, ACM Transactions on Mathematical Software (TOMS), vol.39, issue.3, p.20, 2013. ,
Programming language features, usage patterns, and the efficiency of generated adjoint code, Optimization Methods and Software, vol.31, issue.5, pp.885-903, 2016. ,
Automatic generation of efficient adjoint code for a parallel Navier-Stokes solver, Computational Science ICCS 2002, pp.1019-1028, 2002. ,
An efficient exact adjoint of the parallel mit general circulation model, generated via automatic differentiation, Future Generation Computer Systems, vol.21, issue.8, pp.1356-1371, 2005. ,
Automatic differentiation for message-passing parallel programs, Proceedings of the First Merged International Parallel Processing Symposium and Symposium on Parallel and Distributed Processing, pp.98-104, 1998. ,
Algorithmic differentiation of code with multiple context-specific activities, ACM Trans. Math. Softw, vol.43, issue.4, 2017. ,
Parallelizable adjoint stencil computations using transposed forward-mode algorithmic differentiation, Optimization Methods and Software, vol.33, issue.4-6, pp.672-693, 2018. ,
A proof of the stability of the spectral difference method for all orders of accuracy, Journal of Scientific Computing, vol.45, issue.1-3, pp.348-358, 2010. ,
Preparation and assembly of discrete adjoint CFD codes, 10th ICFD Conference Series on Numerical Methods for Fluid Dynamics, vol.46, pp.282-286, 2011. ,
Effective adjoint approaches for computational fluid dynamics, Progress in Aerospace Sciences, p.100542, 2019. ,
A staggered-grid multidomain spectral method for the compressible navierstokes equations, Journal of computational physics, vol.143, issue.1, pp.125-158, 1998. ,
Spectral difference method for unstructured grids I: basic formulation, Journal of Computational Physics, vol.216, issue.2, pp.780-801, 2006. ,
Technical evaluation report on the fluid dynamics panel symposium on applications of computational fluid dynamics in aeronautics, NASA STI/Recon Technical Report N, vol.87, 1987. ,
STAMPS: a finite-volume solver framework for adjoint codes derived with source-transformation AD, Multidisciplinary Analysis and Optimization Conference, p.2928, 2018. ,
, High-performance derivative computations using CoDiPack, 2017.
Semantics driven adjoints of the message passing interface, 2016. ,
Second-order algorithmic differentiation by source transformation of MPI code, European MPI Users' Group Meeting, pp.257-264, 2010. ,
A wish list for efficient adjoints of one-sided MPI communication, European MPI Users' Group Meeting, pp.248-257, 2012. ,
Interpretative adjoints for numerical simulation codes using mpi, Procedia Computer Science, vol.1, issue.1, pp.1825-1833, 2010. ,
MPI-parallel discrete adjoint openfoam, Procedia Computer Science, vol.51, pp.19-28, 2015. ,
Toward Adjoinable MPI, 2009 IEEE International Symposium on Parallel Distributed Processing, pp.1-8, 2009. ,
On the stability and accuracy of the spectral difference method, Journal of Scientific Computing, vol.37, issue.2, pp.162-188, 2008. ,
Revisiting the spectral analysis for high-order spectral discontinuous methods, Journal of Computational Physics, vol.337, pp.379-402, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01527618
Advantages of binomial checkpointing for memory-reduced adjoint calculations, Numerical mathematics and advanced applications, pp.834-843, 2004. ,
Future directions in computational fluid dynamics, 23rd AIAA Computational Fluid Dynamics Conference, p.3791, 2017. ,
Stabilisation of discrete steady adjoint solvers, Journal of Computational Physics, vol.299, pp.175-195, 2015. ,
