Malware Guard Extension: abusing Intel SGX to conceal cache attacks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cybersecurity Année : 2020
In modern computer systems, user processes are isolated from each other by the operating system and the hardware. Additionally, in a cloud scenario it is crucial that the hypervisor isolates tenants from other tenants that are co-located on the same physical machine. However, the hypervisor does not protect tenants against the cloud provider and thus, the supplied operating system and hardware. Intel SGX provides a mechanism that addresses this scenario. It aims at protecting user-level software from attacks from other processes, the operating system, and even physical attackers. In this paper, we demonstrate fine-grained software-based side-channel attacks from a malicious SGX enclave targeting co-located enclaves. Our attack is the first malware running on real SGX hardware, abusing SGX protection features to conceal itself. Furthermore, we demonstrate our attack both in a native environment and across multiple Docker containers. We perform a Prime+Probe cache side-channel attack on a co-located SGX enclave running an up-to-date RSA implementation that uses a constant-time multiplication primitive. The attack works, although in SGX enclaves, there are no timers, no large pages, no physical addresses, and no shared memory. In a semi-synchronous attack, we extract 96 % of an RSA private key from a single trace. We extract the full RSA private key in an automated attack from 11 traces within 5 min.
malware_guard_extension_journal.pdf (1.71 Mo) Télécharger le fichier
hal-02866628 , version 1 (12-06-2020)
Michael Schwarz, Samuel Weiser, Daniel Gruss, Clémentine Maurice, Stefan Mangard. Malware Guard Extension: abusing Intel SGX to conceal cache attacks. Cybersecurity, 2020, 3 (1), ⟨10.1186/s42400-019-0042-y⟩. ⟨hal-02866628⟩
126 Consultations
427 Téléchargements
