Data Driven Network Performance Inference From Within The Browser - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The ability to monitor web and network performance becomes crucial to understand the reasons behind any service degradation. Such monitoring is also helpful to understand the relationship between the quality of experience of end users and the underlying network performance. Many troubleshooting tools have been proposed recently. They mainly consist of conducting active network measurements from within the browser. However, most of these tools either lack accuracy, or perform measurements to a limited set of servers. They are also known to introduce non-negligible overhead onto the network. The objective of this paper is to propose a new approach based on passive measurements freely available from within the web browser, and to couple these measurements to deep learning models to estimate the latency and bandwidth metrics of the underlying network without injecting any additional measurement traffic. We develop and implement our approach, and compare its estimation accuracy with the best known web-based network measurement techniques available nowadays. We follow a controlled experimental approach to derive our inference models. The results of our study show that our approach can give a very good accuracy compared to others, its accuracy is even higher than most standard techniques, and very close to the rest.
PEDISWESA2020.pdf (567.61 Ko) Télécharger le fichier
hal-02871873 , version 1 (17-06-2020)
Imane Taibi, Yassine Hadjadj-Aoul, Chadi Barakat. Data Driven Network Performance Inference From Within The Browser. PEDISWESA 2020 - 12th IEEE Workshop on Performance Evaluation of Communications in Distributed Systems and Web based Service Architectures, Jul 2020, Rennes, France. pp.1-6, ⟨10.1109/ISCC50000.2020.9219573⟩. ⟨hal-02871873⟩
130 Consultations
167 Téléchargements
