AI-Augmented Multi Function Radar Engineering with Digital Twin: Towards Proactivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mathieu Klein
  • Fonction : Auteur
  • PersonId : 983019
Thomas Carpentier
  • Fonction : Auteur
  • PersonId : 1073304
Eric Jeanclaude
  • Fonction : Auteur
  • PersonId : 1073305
Rami Kassab
  • Fonction : Auteur
  • PersonId : 848419
Nico de Bruijn
  • Fonction : Auteur
  • PersonId : 1073306
Frédéric Barbaresco
Yann Briheche
  • Fonction : Auteur
  • PersonId : 1073307
Yann Semet
  • Fonction : Auteur
  • PersonId : 830846
Florence Aligne
  • Fonction : Auteur
  • PersonId : 1073308
Thales new generation digital multi-missions radars, fully-digital and software-defined, like the Sea Fire and Ground Fire radars, benefit from a considerable increase of accessible degrees of freedoms to optimally design their operational modes. To effectively leverage these design choices and turn them into operational capabilities, it is necessary to develop new engineering tools, using artificial intelligence. Innovative optimization algorithms in the discrete and continuous domains, coupled with a radar Digital Twins, allowed construction of a generic tool for "search" mode design (beam synthesis, waveform and volume grid) compliant with the available radar time budget. The high computation speeds of these algorithms suggest tool application in a "Proactive Radar" configuration, which would dynamically propose to the operator, operational modes better adapted to environment, threats and the equipment failure conditions.
Digital-Twin AI-Augmented MFR Radar Engineering-11-04-2020.pdf (983.83 Ko) Télécharger le fichier
hal-02872199 , version 1 (17-06-2020)
Mathieu Klein, Thomas Carpentier, Eric Jeanclaude, Rami Kassab, Konstantinos Varelas, et al.. AI-Augmented Multi Function Radar Engineering with Digital Twin: Towards Proactivity. 2020 IEEE International Radar Conference, Sep 2020, Florence, Italy. ⟨hal-02872199⟩
567 Consultations
512 Téléchargements
