New interface
Conference papers
Using Dynamic Broadcasts to improve Task-Based Runtime Performances
Alexandre Denis 1, 2 Emmanuel Jeannot 1, 2 Philippe Swartvagher 1, 2 Samuel Thibault 2, 3
1 TADAAM - Topology-Aware System-Scale Data Management for High-Performance Computing
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest
3 STORM - STatic Optimizations, Runtime Methods
Abstract : Task-based runtimes have emerged in the HPC world to take benefit from the computation power of heterogeneous supercomputers and to achieve scalability. One of the main bottlenecks for scalability is the communication layer. Some task-based algorithms need to send the same data to multiple nodes. To optimize this communication pattern , libraries propose dedicated routines, such as MPI Bcast. However, MPI Bcast requirements do not fit well with the constraints of task-based runtime systems: it must be performed simultaneously by all involved nodes, and these must know each other, which is not possible when each node runs a task scheduler not synchronized with others. In this paper, we propose a new approach, called dynamic broadcasts to overcome these constraints. The broadcast communication pattern required by the task-based algorithm is detected automatically, then the broadcasting algorithm relies on active messages and source routing, so that participating nodes do not need to know each other and do not need to synchronize. Receiver receives data the same way as it receives point-to-point communication, without having to know it arrives through a broadcast. We have implemented the algorithm in the StarPU runtime system using the NewMadeleine communication library. We performed benchmarks using the Cholesky factorization that is known to use broadcasts and observed up to 30% improvement of its total execution time.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-02872765
Contributor : Philippe SWARTVAGHER Connect in order to contact the contributor
Submitted on : Wednesday, June 17, 2020 - 7:46:00 PM
Last modification on : Saturday, July 23, 2022 - 3:53:13 AM
File
dynamic_broadcasts.pdf
Identifiers
Citation
Alexandre Denis, Emmanuel Jeannot, Philippe Swartvagher, Samuel Thibault. Using Dynamic Broadcasts to improve Task-Based Runtime Performances. Euro-Par - 26th International European Conference on Parallel and Distributed Computing, Rzadca and Malawski, Aug 2020, Warsaw, Poland. ⟨10.1007/978-3-030-57675-2_28⟩. ⟨hal-02872765⟩
Share
Metrics
Record views
296
Files downloads
337
