Simplicial and continuation methods for approximating fixed points and solutions to systems of equations, Siam review, vol.22, issue.1, pp.28-85, 1980. ,
Estimates for piecewise linear approximations of implicitly defined manifolds, Applied Mathematics Letters, vol.2, issue.2, pp.111-115, 1989. ,
Numerical continuation methods: an introduction, vol.13, 1990. ,
Geometry-driven collapses for converting a ?ech complex into a triangulation of a nicely triangulable shape, Discrete & Computational Geometry, vol.54, issue.4, pp.798-825, 2015. ,
Stratification learning through homology inference, 2010 AAAI Fall Symposium Series, 2010. ,
Inferring local homology from sampled stratified spaces, Proceedings of the IEEE Symposium on Foundations of Computer Science, pp.536-546, 2007. ,
The Stability of Delaunay Triangulations, International Journal of Computional Geometry & Applications, vol.23, issue.4-5, pp.303-334, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00807050
Anisotropic triangulations via discrete Riemannian Voronoi diagrams, SIAM Journal on Computing, vol.48, issue.3, pp.1046-1097, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01507111
Cambridge Texts in Applied Mathematics, 2018. ,
Isotopic implicit surface meshing, Discrete & Computational Geometry, vol.39, issue.1, pp.138-157, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00488819
Delaunay stability via perturbations, International Journal of Computational Geometry & Applications, vol.24, issue.02, pp.125-152, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00806107
Delaunay Triangulation of Manifolds, Foundations of Computational Mathematics, vol.45, p.38, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-00879133
Local conditions for triangulating submanifolds of Euclidean space, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02267620
Manifold reconstruction using tangential Delaunay complexes, Discrete & Computational Geometry, vol.51, issue.1, pp.221-267, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00487862
Triangulating submanifolds: An elementary and quantified version of Whitney's method, 2018. ,
Sampling and Meshing Submanifolds in High Dimension, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02386169
The topological correctness of PL-approximations of isomanifolds, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02386193
Über Abbildung von Mannigfaltigkeiten, Mathematische Annalen, vol.71, issue.4, pp.598-598, 1912. ,
Solution manifold and its statistical applications, p.2020 ,
Manifold reconstruction from point samples, Proc. 16th ACM-SIAM Symp. Discrete Algorithms, pp.1018-1027, 2005. ,
Delaunay Mesh Generation. Computer and information science series, vol.20, p.17, 2013. ,
Coxeter triangulations have good quality, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01667404
Optimization and Nonsmooth Analysis, Classics in applied mathematics. SIAM, vol.5, 1990. ,
Discrete groups generated by reflections, Annals of Mathematics, pp.588-621, 1934. ,
Curve and Surface Reconstruction; Algorithms with Mathematical Analysis, 2007. ,
Delaunay meshing of piecewise smooth complexes without expensive predicates, Algorithms, vol.2, issue.4, pp.1327-1349, 2009. ,
Localized Delaunay refinement for volumes, Computer Graphics Forum, vol.30, issue.5, pp.1417-1426, 2011. ,
Localized Delaunay refinement for piecewisesmooth complexes, Symposium on Computational Geometry 2013, SoCG '13, pp.47-56, 2013. ,
An efficient method of triangulating equi-valued surfaces by using tetrahedral cells, IEICE TRANSACTIONS on Information and Systems, p.74, 1991. ,
, Multidimensional Real Analysis I: Differentiation. Number 86 in Cambridge Studies in Advanced Mathematics, 2004.
Surface sampling and the intrinsic Voronoi diagram, Computer Graphics Forum (Special Issue of Symp. Geometry Processing), vol.27, pp.1393-1402, 2008. ,
A course in triangulations for solving equations with deformations, Lecture Notes in Economics and Mathematical Systems, vol.234, 1984. ,
Triangulating topological spaces, International Journal of Computational Geometry & Applications, vol.7, issue.04, pp.365-378, 1997. ,
Simplizialzerlegungen von beschrankter flachheit, Annals of Mathematics, pp.580-582, 1942. ,
, Differential Topology, 1976.
Some combinatorial lemmas in topology, IBM Journal of research and development, vol.4, issue.5, pp.518-524, 1960. ,
Marching cubes: A high resolution 3d surface construction algorithm, ACM SIGGRAPH Computer Graphics, vol.21, pp.163-169, 1987. ,
, Morse Theory, 1969.
, Lectures on the H-Cobordism Theorem, 1965.
Simplicial isosurfacing in arbitrary dimension and codimension, Journal of Computational Physics, vol.190, issue.1, pp.295-310, 2003. ,
A survey of the marching cubes algorithm, Computers & Graphics, vol.30, issue.5, pp.854-879, 2006. ,
Meshing Volumes Bounded by Smooth Surfaces, Computational Geometry, Theory and Applications, vol.38, pp.100-110, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00097841
Isotopic approximation of implicit curves and surfaces, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing, vol.20, pp.245-254, 2004. ,
Meshing Volumes bounded by Piecewise Smooth Surfaces. Theses, Université Paris-Diderot -Paris VII, 2007. ,
URL : https://hal.archives-ouvertes.fr/tel-00410864
Discretized Riemannian Delaunay Triangulations, 2017. ,
Introduction to 3-manifolds, vol.151, 2014. ,
Lecture notes on Delaunay mesh generation, 1999. ,
The computation of fixed points and applications, Lecture Notes in Economics and Mathematical Systems, vol.124, 1976. ,
Geometric Integration Theory, 1957. ,
