The Topological Correctness of PL-Approximations of Isomanifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Isomanifolds are the generalization of isosurfaces to arbitrary dimension and codimension, i.e. manifolds defined as the zero set of some multi-variate multivalued smooth function f : R^d → R^{d−n}. A natural (and efficient) way to approximate an isomanifold is to consider its Piecewise-Linear (PL) approximation based on a triangulation T of the ambient space R d. In this paper, we give conditions under which the PL-approximation of an isomani-fold is topologically equivalent to the isomanifold. The conditions are easy to satisfy in the sense that they can always be met by taking a sufficiently fine and thick triangulation T. This contrasts with previous results on the triangulation of manifolds where, in arbitrary dimensions, delicate perturbations are needed to guarantee topological correctness, which leads to strong limitations in practice. We further give a bound on the Fréchet distance between the original isomanifold and its PL-approximation. Finally we show analogous results for the PL-approximation of an isomanifold with boundary.
isomanifolds-submittedFoCM.pdf (1.17 Mo) Télécharger le fichier
hal-02874720 , version 1 (19-06-2020)
hal-02874720 , version 2 (22-06-2020)
  • HAL Id : hal-02874720 , version 1
J.-D Boissonnat, M Wintraecken. The Topological Correctness of PL-Approximations of Isomanifolds. 2020. ⟨hal-02874720v1⟩
109 Consultations
50 Téléchargements
