Deformation Aware Augmented Reality for Craniotomy using 3D/2D Non-rigid Registration of Cortical Vessels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Intra-operative brain shift is a well-known phenomenon that describes non-rigid deformation of brain tissues due to gravity and loss of cerebrospinal fluid among other phenomena. This has a negative influence on surgical outcome that is often based on pre-operative planning where the brain shift is not considered. We present a novel brain-shift aware Augmented Reality method to align pre-operative 3D data onto the deformed brain surface viewed through a surgical microscope. We formulate our non-rigid registration as a Shape-from-Template problem. A pre-operative 3D wire-like deformable model is registered onto a single 2D image of the cortical vessels, which is automatically segmented. This 3D/2D registration drives the underlying brain structures, such as tumors, and compensates for the brain shift in sub-cortical regions. We evaluated our approach on simulated and real data composed of 6 patients. It achieved good quantitative and qualitative results making it suitable for neurosurgical guidance.
haouchine_miccai_2020.pdf (5.56 Mo) Télécharger le fichier
hal-02876726 , version 1 (16-07-2020)
hal-02876726 , version 2 (25-10-2020)
hal-02876726 , version 3 (26-10-2020)
  • HAL Id : hal-02876726 , version 1
Nazim Haouchine, Parikshit Juvekar, William Wells Iii, Stephane Cotin, Alexandra Golby, et al.. Deformation Aware Augmented Reality for Craniotomy using 3D/2D Non-rigid Registration of Cortical Vessels. Medical Image Computing and Computer Assisted Intervention, Oct 2020, Lima, Peru. ⟨hal-02876726v1⟩
314 Consultations
164 Téléchargements
