On systems of ordinary differential equations with generalized homogenous right-hand sides. Izvestia vuzov, Mathematica (in Russian), vol.1, pp.80-88, 1958. ,
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal of Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
On homogeneous distributed parameters equations, IEEE Transactions on Automatic Control, vol.61, issue.11, pp.3657-3662, 2016. ,
Homogeneous Approximation, Recursive Observer Design, and Output Feedback, SIAM Journal of Control and Optimization, vol.47, issue.4, pp.1814-1850, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00362707
Nonlinear feedback design for fixed-time stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
H? control, stabilization, and input-output stability of nonlinear systems with homogeneous properties, Automatica, vol.37, issue.6, pp.819-829, 2001. ,
Finite-time LMI based quadrotor control design under time and state constraints, 2019 IEEE Annual European Control Conference (ECC), 2019. ,
Control of nonlinear dynamical systems: methods and applications, 2008. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
Finite-time observers: application to secure communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00176758
On homogeneity and its application in sliding mode control, Journal of The Franklin Institute, vol.351, issue.4, pp.1866-1901, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942326
Adding an integrator for the stabilization problem, Systems & Control Letters, vol.17, issue.2, pp.89-104, 1991. ,
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005. ,
Non-parametric Tuning og PID Controllers, 2013. ,
Nonlinear and Optimal Control Theory, chapter Input to state stability: Basic concepts and results, pp.163-220, 2007. ,
Sliding Modes in Control Optimization, 1992. ,
Finite-time and fixed-time observer design: Implicit Lyapunov function approach, Automatica, vol.87, issue.1, pp.52-60, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01622356
Robust stabilization of mimo systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.26, issue.1, pp.69-90, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01160052
The peak effect in stationary linear-systems with multivariate inputs and outputs. Automation and Remote Control, vol.49, pp.40-47, 1988. ,
On homogeneous finite-time control for linear evolution equation in Hilbert space, IEEE Transactions on Automatic Control, vol.63, issue.9, pp.3143-3150, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01695475
Integral control design using the implicit lyapunov function approach, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02371919
On systems of ordinary differential equations with generalized homogenous right-hand sides. Izvestia vuzov, Mathematica (in Russian, vol.3, issue.22, pp.157-164, 1961. ,
Geometric homogeneity and stabilization, Proc. IFAC Nonlinear Control Symposium, pp.164-169, 1995. ,
Etude de quelques problèmes de stabilization, 1993. ,
Semigroups of linear operators and applications to partial differential equations, vol.44, 2012. ,
Sliding mode control design using canonical homogeneous norm, International Journal of Robust and Nonlinear Control, vol.29, issue.3, pp.682-701, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01697797
Homogeneity for time-delay systems, IFAC Proceedings Volumes, vol.44, pp.3861-3866, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00628890
Lyapunov Functions and Stability in Control Theory, 2001. ,
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, pp.467-473, 1992. ,
Smooth lyapunov functions for homogeneous differential inclusions, Proceedings of the 41st SICE Annual Conference, pp.1974-1979, 2002. ,
Robust feedback stabilization of linear MIMO systems using generalized homogenization, IEEE Transactions on Automatic Control, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02614543
Linear Multivariable Control: A Geometric Approach, 1985. ,
Differential equations with discontinuous righthand sides, 1988. ,
Sliding order and sliding accuracy in sliding mode control, International Journal of Control, vol.58, issue.6, pp.1247-1263, 1993. ,
Stability by Liapunov's Direct Method with Applications, 1961. ,
Discontinuous systems: Lyapunov analysis and robust synthesis under uncertainty conditions, 2008. ,
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01098099
Switching in systems and control, 2003. ,
Consistent discretization of finite-time and fixed-time stable systems, SIAM Journal on Control and Optimization, vol.57, issue.1, pp.78-103, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01838712
Design and control of quadrotors with application to autonomous flying, 2007. ,
Full control of a quadrotor, IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.153-158, 2007. ,
