On the theories of triangular sets, Journal of Symbolic Computation, vol.28, issue.1, pp.105-124, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01148870
Bertini: Software for numerical algebraic geometry. Available at bertini.nd.edu with permanent doi: dx ,
Globally convergent, iterative path-following for algebraic equations, Math. in Computer Sci, vol.4, issue.4, pp.507-537, 2010. ,
Complexity analysis of root clustering for a complex polynomial, Proceedings of the ACM on International Symposium on Symbolic and Algebraic Computation, vol.16, pp.71-78, 2016. ,
A near-optimal subdivision algorithm for complex root isolation based on Pellet test and Newton iteration, J. Symbolic Computation, vol.86, pp.51-96, 2018. ,
Certified numerical homotopy tracking, Experimental Mathematics, vol.21, issue.1, pp.69-83, 2012. ,
Real root isolation of regular chains, Computer Mathematics, pp.33-48 ,
URL : https://hal.archives-ouvertes.fr/hal-00825036
, , 2014.
Complete numerical isolation of real roots in zero-dimensional triangular systems, Journal of Symbolic Computation, vol.44, issue.7, pp.768-785, 2009. ,
Interval arithmetic in cylindrical algebraic decomposition, Journal of Symbolic Computation, vol.34, issue.2, pp.145-157, 2002. ,
Lifting techniques for triangular decompositions, Proceedings of the 2005 International Symposium on Symbolic and Algebraic Computation. pp. 108-115. ISSAC '05, 2005. ,
Sur les développements en série des fonctions d'une seule variable, Journal de mathématiques pures et appliquées (Liouville Journal), vol.3, pp.291-312, 1876. ,
Computing the multiplicity structure in solving polynomial systems, Proceedings of the 2005 international symposium on Symbolic and algebraic computation, pp.116-123, 2005. ,
, Solving Polynomial Equations: Foundations, Algorithms, and Applications, 2005.
A Descartes Algorithm for Polynomials with Bit-Stream Coefficients, CASC. LNCS, vol.3718, pp.138-149, 2005. ,
On location and approximation of clusters of zeros: Case of embedding dimension one, Foundations of Computational Mathematics, vol.7, issue.1, pp.1-58, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00186739
A polyhedral method for solving sparse polynomial systems, Mathematics of computation, vol.64, issue.212, pp.1541-1555, 1995. ,
Implementation of a near-optimal complex root clustering algorithm, Mathematical Software -ICMS 2018, pp.235-244, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02077920
Arb: efficient arbitrary-precision midpoint-radius interval arithmetic, IEEE Transactions on Computers, vol.66, pp.1281-1292, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01394258
Computing real roots of real polynomials ... and now for real, Proceedings of the ACM on International Symposium on Symbolic and Algebraic Computation, vol.16, pp.303-310, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01363955
Local Generic Position for Root Isolation of Zerodimensional Triangular Polynomial Systems, CASC 2012 -14th International Workshop on Computer Algebra in Scientific Computing, vol.7442, pp.186-197, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00776212
On the distance between the roots of a polynomial, Communication and Computing, vol.6, issue.6, pp.327-332, 1995. ,
Introduction to interval analysis, 2009. ,
, Bounds for polynomials on algebraic numbers and application to curve topology, 2018.
Univariate real root isolation in an extension field and applications, Journal of Symbolic Computation, vol.92, pp.31-51, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01248390
The Numerical solution of systems of polynomials arising in engineering and science, 2005. ,
An approach for certifying homotopy continuation paths: Univariate case, Proceedings of the 2018 ACM International Symposium on Symbolic and Algebraic Computation, vol.18, pp.399-406, 2018. ,
Analytic root clustering: A complete algorithm using soft zero tests, The Nature of Computation. Logic, Algorithms, Applications. LNCS, vol.7921, pp.434-444, 2013. ,
Real solution isolation with multiplicity of zerodimensional triangular systems, Science China Information Sciences, vol.54, issue.1, pp.60-69, 2011. ,
