Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
On the Significance of Layer-3 Traffic Forwarding
Abstract : Designing performance-enhanced and large-scale overlay networks over the conventional IP substrate encounters different implementation obstacles put in place by Internet Service Providers (ISPs). These include lack of proper privileges and restrictive routing policies that prevent the overlay services from being deployed easily. The evolution of Software Defined Networks (SDNs), however, helps to address these concerns by simplifying the mechanism for overlay router design. In this paper, we have included an analysis of 18,906 delay traces from a network of 138 hosts. Our main aim was to demonstrate the rich existence of IP overlay paths that can be leveraged to significantly enhance Internet routing performance. We try to make the case for using layer-3 forwarding minimum delay overlay paths by demonstrating superior performance in this approach compared to existing overlay designs which work mostly at the TCP and application layers. In particular, the study was conducted to benefit applications that are sensitive to end-to-end delay and throughput. This paper presents a specific analysis of end-to-end delay in order to enhance TCP performance. The current work aims at increasing throughput and reducing file transfer time via overlay while maintaining simplicity and preserving all TCP characteristics. The results of this study show that the use of the shortest delay paths between physically disjoint node pairs can benefit TCP throughput and minimize file transfer time by orders of magnitude. The ultimate objective behind this study is to develop a reliable and scalable over-lay design for file transfers that require high transmission rates.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-02881736
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, June 26, 2020 - 8:44:01 AM
Last modification on : Friday, June 26, 2020 - 8:56:56 AM
File
481347_1_En_14_Chapter.pdf
Identifiers
Citation
Salim Mohamed, Saptarshi Das, Subir Biswas, Osama Mohammed. On the Significance of Layer-3 Traffic Forwarding. 17th International Conference on Wired/Wireless Internet Communication (WWIC), Jun 2019, Bologna, Italy. pp.170-181, ⟨10.1007/978-3-030-30523-9_14⟩. ⟨hal-02881736⟩
Share
Metrics
Record views
45
Files downloads
5
